Upgrading to RouterOS 4.0
Please clarify:
The update process discribed in the PDF is cloudy at best in its discription…
  1. Update the Bootloader if using a RouterBOARD
  2. If already running RouterOS v3.25 or newer, Update your RouterOS license
  3. If you will use Netinstall for installation, make sure you have the latest version of Netinstall
I have about 8 routers to upgrade and I want to get this right the first time.
I did find the wiki about the Bootloader upgrade and that explianed how but not the ‘does this apply to my routers?’ question.
The routers that I can upgrade.
The majority of these are RB450 where System > Packages > RouterBoard is v3.30.
Do I still need to upgrade the Bootloader on these?
System > License > Upgradable To field indicates v4x.
What happens when I click Upgrade license key and is that all I need to do?
Do I assume that it just goes out to your server and gets a new key? If so, is the router then ready for the new OS?
OR
Do I still need to purchase an upgrade license first, then import the key and then install the new OS?
OR
Do I just use the Buy New Key button and then install the new OS?
With all these options on the License window, it is really confusing as to what I need to do and what step by step process should be for our particular routers.
NOTE I did find the wiki about licenses which did not explain the ugrade process.
Thank you.
Ok you can ignor this post.. I figured it out! It was just as simple as following the directions which are clearly posted when attempting to download the new RouterOS v 4.0. I am sorry I didn’t notice the link in the warning the first time through.
Thank you.
what was you found brother.i need help in same direction.
just need the steps where to get file and how upgrade.
Thank you brother
http://wiki.mikrotik.com/wiki/Upgrading_RouterOS
