Hi all, I’m trying to add additional WAN connections on my RB1100, I have all ports in use using PCC, now I want to add an uplink router and change the weighting on the primary router to spread my WAN connections over the primary router and the uplink router. I have created a /30 subnet to connect a port on the the primary to the uplink, I’ve removed NAT from this port and have set static routes on both routers, I can ping the routers from each other, I can ping my LAN from the uplink router but cannot ping the uplink router from my LAN. I cant get internet traffic to pass over to the uplink router, I can ping the internet from my uplink router too. I’ve exported the config from both routers, I’ve removed the non essential configs. Any pointers/help much appreciated.
Ether1 is my LAN
Cyta12 is one of my WAN’s on the primary router
Uplink is my connection to the uplink router.
Primary router config:
add address=172.16.1.254/16 interface=ether1 network=172.16.0.0
add address=10.2.2.1/30 interface=cyta12 network=10.2.2.0
add address=192.168.4.1/30 interface=uplink network=192.168.4.0
add chain=input in-interface=ether1 protocol=icmp
add chain=input in-interface=uplink protocol=icmp
add chain=input connection-state=established in-interface=cyta12
add chain=input connection-state=related in-interface=cyta12
add chain=input connection-state=established in-interface=uplink
add chain=input connection-state=related in-interface=uplink
/ip firewall mangle
add chain=prerouting dst-address=10.2.2.0/30 in-interface=ether1
add chain=prerouting dst-address=192.168.4.0/30 in-interface=ether1
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=cyta12 new-connection-mark=cyta12_conn
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=uplink new-connection-mark=uplink_conn
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local hotspot=“” in-interface=ether1 new-connection-mark=cyta12_conn per-connection-classifier=src-address:2/0
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local hotspot=“” in-interface=ether1 new-connection-mark=uplink_conn per-connection-classifier=src-address:2/1
add action=mark-routing chain=prerouting connection-mark=cyta12_conn in-interface=ether1 new-routing-mark=to_cyta12
aad action=mark-routing chain=prerouting connection-mark=uplink_conn in-interface=ether1 new-routing-mark=to_uplink
add action=mark-routing chain=output connection-mark=cyta12_conn hotspot=“” new-routing-mark=to_cyta12
add action=mark-routing chain=output connection-mark=uplink_conn hotspot=“” new-routing-mark=to_uplink
add action=masquerade chain=srcnat out-interface=cyta12 to-addresses=10.2.2.1
add check-gateway=ping distance=1 gateway=10.2.2.2 routing-mark=to_cyta12
add check-gateway=ping distance=1 gateway=192.168.4.2 routing-mark=uplink
add check-gateway=ping distance=2 gateway=10.2.2.2
add check-gateway=ping distance=3 gateway=192.168.4.2
Uplink router config:
add address=192.168.4.2/30 interface=ether1 network=192.168.4.0
add address=10.1.1.1/30 interface=cyta13 network=10.1.1.0
add chain=input in-interface=cyta13 protocol=icmp
add chain=input connection-state=established in-interface=cyta13
add chain=input connection-state=related in-interface=cyta13
/ip firewall mangle
add chain=prerouting dst-address=10.1.1.0/30 in-interface=ether1
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=cyta13 new-connection-mark=cyta13_conn
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local hotspot=“” in-interface=ether1 new-connection-mark=cyta13_conn per-connection-classifier=src-address:1/0
add action=mark-routing chain=prerouting connection-mark=cyta13_conn in-interface=ether1 new-routing-mark=to_cyta13
add action=mark-routing chain=output connection-mark=cyta13_conn hotspot=“” new-routing-mark=to_cyta13
add action=masquerade chain=srcnat out-interface=cyta13
add check-gateway=ping distance=1 gateway=10.1.1.2 routing-mark=to_cyta13
add check-gateway=ping distance=1 dst-address=172.16.0.0/16 gateway=192.168.4.1
