can mikrotik Limit Upload ???/
Yes, of course. Just the same as limiting download. In simple queues this is all in one entry separated by / e.g. 128000/512000. In queue trees you need to specify separate queues for up and down.
Does that really work? I did something like above (simple queue) but when I look at the Bps column, only one side of the / shows activity…
I configured MT 2.8.21 as a transparent bridge for traffic shapping, but it seems only one side of the shape (download) is working. Any better way to do it?
Thanks in anticipation of your cherished assistance…
Tonnie
I’ve never seen that before, where only one direction shows activity in the list of simple queues. However, I’m not using the router as a bridge, but as a full NAT router.
Perhaps send your supout file to support@mikrotik.com.
sorry for the OT, but could you comment about NAT’ed payload, particularly DNS requests. are they translated correctly? i.e. will an outside client see the correct public ip-address, if there’s a DNS-server behind NAT.
i’ve been asking this in http://www.mikrotik.com/forum/viewtopic.php?t=1534 but nobody answered yet.
tia.
matthias
[quote=“GJS”]I’ve never seen that before, where only one direction shows activity in the list of simple queues. However, I’m not using the router as a bridge, but as a full NAT router.
I tried that earlier on, but with the same observation. What interface did you put your queue on?
Cheers!!
