hi plz can anyone help me i have a problem with upload my internet need more upload but i can’t get this upload my internet want between 15mb and 20mb i can’t get them maximum what i can get it is 10mb
mikrotik for best performance
If your line is insufficient, buy more throughput from your provider or add other line from another provider.
Post here the export from your config please, so we can see whats wrong
Sensitive data like paswords can you change with XXX
I have bandwith but i can’t reach them i have 20E1
Why you didn’t post what device are you using and how it is set?
It a ccr what do you want i will post ?
Go to “new terminal”
type: export
copy and paste that on this forum
edit sensitive data like paswords with XX
What states in profile when you reach the throughput limit?
Balancer(not load balance) shaper or pppoe
oct/10/2014 18:36:37 by RouterOS 6.3
software id = XP5I-CZ82
/certificate template
add days-valid=365 key-size=2048
add l2mtu=1590 name=bridge
set 0 comment="20 Mbps"
set 4 comment="70 mbps"
set 9 disabled=yes
set 11 disabled=yes
/ip neighbor discovery
set "ether1 / To Main Router 209 / Fiber" comment="20 Mbps"
set "ether5 / VISP" comment="70 mbps"
/ip firewall layer7-protocol
add name=skypeout regexp="^(\x01.?.?.?.?.?.?.?.?\x01|\x02.?.?.?.
?.?.?.?.?\x02|\x03.?.?.?.?.?.?.?.?\x03|\x04.?.?.?.?.?
.?.?.?\x04|\x05.?.?.?.?.?.?.?.?\x05|\x06.?.?.?.?.?.?.
?.?\x06|\x07.?.?.?.?.?.?.?.?\x07|\x08.?.?.?.?.?.?.?.?
\x08|\x09.?.?.?.?.?.?.?.?\x09|\x0a.?.?.?.?.?.?.?.?\x0a
|\x0b.?.?.?.?.?.?.?.?\x0b|\x0c.?.?.?.?.?.?.?.?\x0c|\x0
d.?.?.?.?.?.?.?.?\x0d|\x0e.?.?.?.?.?.?.?.?\x0e|\x0f.?.
?.?.?.?.?.?.?\x0f|\x10.?.?.?.?.?.?.?.?\x10|\x11.?.?.?
.?.?.?.?.?\x11|\x12.?.?.?.?.?.?.?.?\x12|\x13.?.?.?.?.
?.?.?.?\x13|\x14.?.?.?.?.?.?.?.?\x14|\x15.?.?.?.?.?.?
.?.?\x15|\x16.?.?.?.?.?.?.?.?\x16|\x17.?.?.?.?.?.?.?.
?\x17|\x18.?.?.?.?.?.?.?.?\x18|\x19.?.?.?.?.?.?.?.?\x
19|\x1a.?.?.?.?.?.?.?.?\x1a|\x1b.?.?.?.?.?.?.?.?\x1b|\
x1c.?.?.?.?.?.?.?.?\x1c|\x1d.?.?.?.?.?.?.?.?\x1d|\x1e.
?.?.?.?.?.?.?.?\x1e|\x1f.?.?.?.?.?.?.?.?\x1f|\x20.?.?
.?.?.?.?.?.?\x20|\x21.?.?.?.?.?.?.?.?\x21|\x22.?.?.?.
?.?.?.?.?\x22|\x23.?.?.?.?.?.?.?.?\x23|\$.?.?.?.?.?.
?.?.?\$|\x25.?.?.?.?.?.?.?.?\x25|\x26.?.?.?.?.?.?.?.
?\x26|\x27.?.?.?.?.?.?.?.?\x27|\(.?.?.?.?.?.?.?.?\(|
?.?.?.?.?\+|\x2c.?.?.?.?.?.?.?.?\x2c|\x2d.?.?.?.?.?.
?.?.?\x2d|\..?.?.?.?.?.?.?.?\.|\x2f.?.?.?.?.?.?.?.?
\x2f|\x30.?.?.?.?.?.?.?.?\x30|\x31.?.?.?.?.?.?.?.?\x31
|\x32.?.?.?.?.?.?.?.?\x32|\x33.?.?.?.?.?.?.?.?\x33|\x3
4.?.?.?.?.?.?.?.?\x34|\x35.?.?.?.?.?.?.?.?\x35|\x36.?.
?.?.?.?.?.?.?\x36|\x37.?.?.?.?.?.?.?.?\x37|\x38.?.?.?
.?.?.?.?.?\x38|\x39.?.?.?.?.?.?.?.?\x39|\x3a.?.?.?.?.
?.?.?.?\x3a|\x3b.?.?.?.?.?.?.?.?\x3b|\x3c.?.?.?.?.?.?
.?.?\x3c|\x3d.?.?.?.?.?.?.?.?\x3d|\x3e.?.?.?.?.?.?.?.
?\x3e|\?.?.?.?.?.?.?.?.?\?|\x40.?.?.?.?.?.?.?.?\x40
|\x41.?.?.?.?.?.?.?.?\x41|\x42.?.?.?.?.?.?.?.?\x42|\x4
3.?.?.?.?.?.?.?.?\x43|\x44.?.?.?.?.?.?.?.?\x44|\x45.?.
?.?.?.?.?.?.?\x45|\x46.?.?.?.?.?.?.?.?\x46|\x47.?.?.?
.?.?.?.?.?\x47|\x48.?.?.?.?.?.?.?.?\x48|\x49.?.?.?.?.
?.?.?.?\x49|\x4a.?.?.?.?.?.?.?.?\x4a|\x4b.?.?.?.?.?.?
.?.?\x4b|\x4c.?.?.?.?.?.?.?.?\x4c|\x4d.?.?.?.?.?.?.?.
?\x4d|\x4e.?.?.?.?.?.?.?.?\x4e|\x4f.?.?.?.?.?.?.?.?\x
4f|\x50.?.?.?.?.?.?.?.?\x50|\x51.?.?.?.?.?.?.?.?\x51|\
x52.?.?.?.?.?.?.?.?\x52|\x53.?.?.?.?.?.?.?.?\x53|\x54.
?.?.?.?.?.?.?.?\x54|\x55.?.?.?.?.?.?.?.?\x55|\x56.?.?
.?.?.?.?.?.?\x56|\x57.?.?.?.?.?.?.?.?\x57|\x58.?.?.?.
?.?.?.?.?\x58|\x59.?.?.?.?.?.?.?.?\x59|\x5a.?.?.?.?.?
.?.?.?\x5a|\[.?.?.?.?.?.?.?.?\[|\\.?.?.?.?.?.?.?.?
\\|\].?.?.?.?.?.?.?.?\]|\^.?.?.?.?.?.?.?.?\^|\x5f.?
.?.?.?.?.?.?.?\x5f|\x60.?.?.?.?.?.?.?.?\x60|\x61.?.?.
?.?.?.?.?.?\x61|\x62.?.?.?.?.?.?.?.?\x62|\x63.?.?.?.?
.?.?.?.?\x63|\x64.?.?.?.?.?.?.?.?\x64|\x65.?.?.?.?.?.
?.?.?\x65|\x66.?.?.?.?.?.?.?.?\x66|\x67.?.?.?.?.?.?.?
.?\x67|\x68.?.?.?.?.?.?.?.?\x68|\x69.?.?.?.?.?.?.?.?\
x69|\x6a.?.?.?.?.?.?.?.?\x6a|\x6b.?.?.?.?.?.?.?.?\x6b|
\x6c.?.?.?.?.?.?.?.?\x6c|\x6d.?.?.?.?.?.?.?.?\x6d|\x6e
.?.?.?.?.?.?.?.?\x6e|\x6f.?.?.?.?.?.?.?.?\x6f|\x70.?.
?.?.?.?.?.?.?\x70|\x71.?.?.?.?.?.?.?.?\x71|\x72.?.?.?
.?.?.?.?.?\x72|\x73.?.?.?.?.?.?.?.?\x73|\x74.?.?.?.?.
?.?.?.?\x74|\x75.?.?.?.?.?.?.?.?\x75|\x76.?.?.?.?.?.?
.?.?\x76|\x77.?.?.?.?.?.?.?.?\x77|\x78.?.?.?.?.?.?.?.
?\x78|\x79.?.?.?.?.?.?.?.?\x79|\x7a.?.?.?.?.?.?.?.?\x
7a|\{.?.?.?.?.?.?.?.?\{|\|.?.?.?.?.?.?.?.?\||\}.?.?.
?.?.?.?.?.?\}|\x7e.?.?.?.?.?.?.?.?\x7e|\x7f.?.?.?.?.
?.?.?.?\x7f|\x80.?.?.?.?.?.?.?.?\x80|\x81.?.?.?.?.?.?
.?.?\x81|\x82.?.?.?.?.?.?.?.?\x82|\x83.?.?.?.?.?.?.?.
?\x83|\x84.?.?.?.?.?.?.?.?\x84|\x85.?.?.?.?.?.?.?.?\x
85|\x86.?.?.?.?.?.?.?.?\x86|\x87.?.?.?.?.?.?.?.?\x87|\
x88.?.?.?.?.?.?.?.?\x88|\x89.?.?.?.?.?.?.?.?\x89|\x8a.
?.?.?.?.?.?.?.?\x8a|\x8b.?.?.?.?.?.?.?.?\x8b|\x8c.?.?
.?.?.?.?.?.?\x8c|\x8d.?.?.?.?.?.?.?.?\x8d|\x8e.?.?.?.
?.?.?.?.?\x8e|\x8f.?.?.?.?.?.?.?.?\x8f|\x90.?.?.?.?.?
.?.?.?\x90|\x91.?.?.?.?.?.?.?.?\x91|\x92.?.?.?.?.?.?.
?.?\x92|\x93.?.?.?.?.?.?.?.?\x93|\x94.?.?.?.?.?.?.?.?
\x94|\x95.?.?.?.?.?.?.?.?\x95|\x96.?.?.?.?.?.?.?.?\x96
|\x97.?.?.?.?.?.?.?.?\x97|\x98.?.?.?.?.?.?.?.?\x98|\x9
9.?.?.?.?.?.?.?.?\x99|\x9a.?.?.?.?.?.?.?.?\x9a|\x9b.?.
?.?.?.?.?.?.?\x9b|\x9c.?.?.?.?.?.?.?.?\x9c|\x9d.?.?.?
.?.?.?.?.?\x9d|\x9e.?.?.?.?.?.?.?.?\x9e|\x9f.?.?.?.?.
?.?.?.?\x9f|\xa0.?.?.?.?.?.?.?.?\xa0|\xa1.?.?.?.?.?.?
.?.?\xa1|\xa2.?.?.?.?.?.?.?.?\xa2|\xa3.?.?.?.?.?.?.?.
?\xa3|\xa4.?.?.?.?.?.?.?.?\xa4|\xa5.?.?.?.?.?.?.?.?\x
a5|\xa6.?.?.?.?.?.?.?.?\xa6|\xa7.?.?.?.?.?.?.?.?\xa7|\
xa8.?.?.?.?.?.?.?.?\xa8|\xa9.?.?.?.?.?.?.?.?\xa9|\xaa.
?.?.?.?.?.?.?.?\xaa|\xab.?.?.?.?.?.?.?.?\xab|\xac.?.?
.?.?.?.?.?.?\xac|\xad.?.?.?.?.?.?.?.?\xad|\xae.?.?.?.
?.?.?.?.?\xae|\xaf.?.?.?.?.?.?.?.?\xaf|\xb0.?.?.?.?.?
.?.?.?\xb0|\xb1.?.?.?.?.?.?.?.?\xb1|\xb2.?.?.?.?.?.?.
?.?\xb2|\xb3.?.?.?.?.?.?.?.?\xb3|\xb4.?.?.?.?.?.?.?.?
\xb4|\xb5.?.?.?.?.?.?.?.?\xb5|\xb6.?.?.?.?.?.?.?.?\xb6
|\xb7.?.?.?.?.?.?.?.?\xb7|\xb8.?.?.?.?.?.?.?.?\xb8|\xb
9.?.?.?.?.?.?.?.?\xb9|\xba.?.?.?.?.?.?.?.?\xba|\xbb.?.
?.?.?.?.?.?.?\xbb|\xbc.?.?.?.?.?.?.?.?\xbc|\xbd.?.?.?
.?.?.?.?.?\xbd|\xbe.?.?.?.?.?.?.?.?\xbe|\xbf.?.?.?.?.
?.?.?.?\xbf|\xc0.?.?.?.?.?.?.?.?\xc0|\xc1.?.?.?.?.?.?
.?.?\xc1|\xc2.?.?.?.?.?.?.?.?\xc2|\xc3.?.?.?.?.?.?.?.
?\xc3|\xc4.?.?.?.?.?.?.?.?\xc4|\xc5.?.?.?.?.?.?.?.?\x
c5|\xc6.?.?.?.?.?.?.?.?\xc6|\xc7.?.?.?.?.?.?.?.?\xc7|\
xc8.?.?.?.?.?.?.?.?\xc8|\xc9.?.?.?.?.?.?.?.?\xc9|\xca.
?.?.?.?.?.?.?.?\xca|\xcb.?.?.?.?.?.?.?.?\xcb|\xcc.?.?
.?.?.?.?.?.?\xcc|\xcd.?.?.?.?.?.?.?.?\xcd|\xce.?.?.?.
?.?.?.?.?\xce|\xcf.?.?.?.?.?.?.?.?\xcf|\xd0.?.?.?.?.?
.?.?.?\xd0|\xd1.?.?.?.?.?.?.?.?\xd1|\xd2.?.?.?.?.?.?.
?.?\xd2|\xd3.?.?.?.?.?.?.?.?\xd3|\xd4.?.?.?.?.?.?.?.?
\xd4|\xd5.?.?.?.?.?.?.?.?\xd5|\xd6.?.?.?.?.?.?.?.?\xd6
|\xd7.?.?.?.?.?.?.?.?\xd7|\xd8.?.?.?.?.?.?.?.?\xd8|\xd
9.?.?.?.?.?.?.?.?\xd9|\xda.?.?.?.?.?.?.?.?\xda|\xdb.?.
?.?.?.?.?.?.?\xdb|\xdc.?.?.?.?.?.?.?.?\xdc|\xdd.?.?.?
.?.?.?.?.?\xdd|\xde.?.?.?.?.?.?.?.?\xde|\xdf.?.?.?.?.
?.?.?.?\xdf|\xe0.?.?.?.?.?.?.?.?\xe0|\xe1.?.?.?.?.?.?
.?.?\xe1|\xe2.?.?.?.?.?.?.?.?\xe2|\xe3.?.?.?.?.?.?.?.
?\xe3|\xe4.?.?.?.?.?.?.?.?\xe4|\xe5.?.?.?.?.?.?.?.?\x
e5|\xe6.?.?.?.?.?.?.?.?\xe6|\xe7.?.?.?.?.?.?.?.?\xe7|\
xe8.?.?.?.?.?.?.?.?\xe8|\xe9.?.?.?.?.?.?.?.?\xe9|\xea.
?.?.?.?.?.?.?.?\xea|\xeb.?.?.?.?.?.?.?.?\xeb|\xec.?.?
.?.?.?.?.?.?\xec|\xed.?.?.?.?.?.?.?.?\xed|\xee.?.?.?.
?.?.?.?.?\xee|\xef.?.?.?.?.?.?.?.?\xef|\xf0.?.?.?.?.?
.?.?.?\xf0|\xf1.?.?.?.?.?.?.?.?\xf1|\xf2.?.?.?.?.?.?.
?.?\xf2|\xf3.?.?.?.?.?.?.?.?\xf3|\xf4.?.?.?.?.?.?.?.?
\xf4|\xf5.?.?.?.?.?.?.?.?\xf5|\xf6.?.?.?.?.?.?.?.?\
|\xf7.?.?.?.?.?.?.?.?\xf7|\xf8.?.?.?.?.?.?.?.?\xf8|
9.?.?.?.?.?.?.?.?\xf9|\xfa.?.?.?.?.?.?.?.?\xfa|\xfb.
?.?.?.?.?.?.?\xfb|\xfc.?.?.?.?.?.?.?.?\xfc|\xfd.?.?
.?.?.?.?.?\xfd|\xfe.?.?.?.?.?.?.?.?\xfe|\xff.?.?.?.
?.?.?.?\xff)"
add name=skypetoskype regexp="^..\02............."
add name=videoooo regexp="http/(0\.9|1\.0|1\.1)[\x09-\x0d ][1-5][0-9][0
[\x09-\x0d -~]*(content-type: video)"
add name="vidoe play" regexp=videoplayback
add name=sip regexp="^(invite|register|cancel|message|subscribe|notify) sip[
09-\x0d -~]*sip/[0-2]\.[0-9]"
add name=Youtube regexp=""^.get.+\\.(c.youtube.com|cdn.dailymotion.com|m
cafe.com|mccont.com).\$""
add name=h323 regexp="^\03..\?\08...\?.\?.\?.\?.\?.\?.\?.
.\?.\?.\?.\?.\?.\?.\?\05"
add name=teamspeak regexp="^\F4\BE\03.*teamspeak"
add name=ventrilo regexp="^..\?v\\\$\CF"
add name=stun regexp="[1]................\?\$"
add name=skypenack regexp="[\\\\|\\xd5]"
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
mac-cookie-timeout=3d
\01\02 ↩︎
this is the export of the balancer
jan/04/1970 23:14:49 by RouterOS 6.3
software id = 8ECY-RJCJ
set 7 name="ether8
set 9 name="ether10 "
add name=youtube regexp=youtube.com
add name=x ranges="x"
add name=x ranges=x
add name=xl ranges=x
/port
set 0 name=serial0
set 1 name=serial1
/ppp profile
set 0 dns-server=192.168.166.101,8.8.8.8 local-address=x
only-one=yes remote-address=x use-compression=no use-encryption=no
use-ipv6=no use-mpls=no use-vj-compression=no
add change-tcp-mss=yes dns-server=192.168.166.101 local-address=x
name=511 rate-limit=2048/2048 remote-address=Pexpired use-ipv6=no
wins-server=8.8.8.8
add change-tcp-mss=yes dns-server=192.168.166.101,8.8.8.8 local-address=
x name=512k rate-limit=2048/1024 remote-address=x
set 3 dns-server=192.168.166.101,8.8.8.8 local-address=x
remote-address=x
/queue simple
add name=radius packet-marks=radius priority=1/1 target="" total-priority=1
/queue type
add kind=pcq name=DNS pcq-classifier=src-address,dst-address
pcq-dst-address6-mask=64 pcq-src-address6-mask=64
add kind=pcq name=Thunder pcq-classifier=dst-address pcq-dst-address6-mask=64
pcq-limit=50M pcq-rate=6M pcq-src-address6-mask=64
add kind=pcq name=radius pcq-classifier=dst-address pcq-dst-address6-mask=64
add kind=pcq name="pcq for https" pcq-classifier=dst-address
pcq-dst-address6-mask=64 pcq-rate=750k pcq-src-address6-mask=64
add kind=pcq name="pcq for http" pcq-classifier=dst-address
pcq-dst-address6-mask=64 pcq-rate=512k pcq-src-address6-mask=64
/queue simple
add name=DNS packet-marks=MP_DNS priority=1/1 queue=DNS/DNS target=""
total-priority=1
add name=thunder packet-marks=thunder_packs queue=Thunder/Thunder target=""
/queue tree
add name=THUNDER packet-mark=thunder_packs parent=global queue=Thunder
add name=DNS packet-mark=MP_DNS parent=global queue=DNS
add name=https packet-mark=https parent=global priority=1 queue="pcq for https"
add name=youtube packet-mark=youtube parent=global queue="pcq for https"
add name=http packet-mark=http parent=global queue="pcq for http"
/interface pppoe-server server
add authentication=pap disabled=no interface=ether2 one-session-per-host=yes
add authentication=pap disabled=no interface=ether3 one-session-per-host=yes
add authentication=pap disabled=no interface=ether4 one-session-per-host=yes
add authentication=pap disabled=no interface=ether5 one-session-per-host=yes
add authentication=pap disabled=no interface=ether6 one-session-per-host=yes
add authentication=pap disabled=no interface=ether7 one-session-per-host=yes
add authentication=pap disabled=no interface="ether8 x"
add authentication=pap disabled=no interface=ether12 one-session-per-host=yes
add authentication=pap disabled=no interface=ether13 one-session-per-host=yes
add address=x interface=ether1 network=x
set servers=192.168.166.101,8.8.8.8
/ip firewall mangle
add action=mark-packet chain=prerouting comment=WINBOX dst-port=8291
new-packet-mark=winbox passthrough=no protocol=tcp
add action=mark-packet chain=prerouting comment=radius dst-address=
x dst-port=443 new-packet-mark=radius passthrough=no
protocol=tcp
protocol=tcp
x dst-port=80 new-packet-mark=radius passthrough=no protocol=
tcp
add action=mark-packet chain=prerouting comment=P2P new-packet-mark=P2P p2p=
all-p2p passthrough=no
add action=mark-connection chain=prerouting comment="Unlimited DNS" dst-port=53
new-connection-mark=MC_DNS protocol=udp
add action=mark-packet chain=prerouting comment="Unlimited DNS"
connection-mark=MC_DNS new-packet-mark=MP_DNS passthrough=no
add action=mark-packet chain=prerouting comment=radius new-packet-mark=radius
passthrough=no protocol=tcp src-address=x
add action=mark-packet chain=postrouting comment=Thunder dscp=8
new-packet-mark=thunder_packs protocol=tcp src-port=80
add action=mark-connection chain=prerouting layer7-protocol=youtube
new-connection-mark=youtube
add action=mark-packet chain=forward connection-mark=youtube new-packet-mark=
youtube
add action=mark-connection chain=prerouting new-connection-mark=https port=443
protocol=tcp
add action=mark-packet chain=forward connection-mark=https new-packet-mark=
https
add action=mark-connection chain=prerouting new-connection-mark=http port=80
protocol=tcp time=1s-5h,sun,mon,tue,wed,thu,fri,sat
add action=mark-packet chain=forward connection-mark=http new-packet-mark=http
time=0s-5h,sun,mon,tue,wed,thu,fri,sat
add action=dst-nat chain=dstnat protocol=tcp src-address=x
to-addresses=xto-ports=85
add action=dst-nat chain=dstnat comment=Radius dst-address=x
dst-port=443 protocol=tcp to-addresses=xto-ports=443
dst-port=80 protocol=tcp to-addresses=x to-ports=80
add action=src-nat chain=srcnat src-address=x
to-addresses=x
to-addresses=x
to-addresses=x
to-addresses=x
to-addresses=x
to-addresses=x
add distance=1 gateway=x
/ppp aaa
set use-radius=yes
/radius
add address=x secret=x service=ppp,login
/radius incoming
set accept=yes port=1700
that a pppoe
