upload speed is 25% below download speed
Hello Guys
I have a RB951 and also a Rb2011 and my upload speed when doing a speedtest is always 25% less than the download speed.
I have a 20 mb/s fiber connection to my ISP. It is a symmetric connection and a 1:1 contention.
when I connect to from my laptop directly to their switch, bypassing the Router, I get similiar upload and download speeds, but with the router connected
in the middle I always get slower upload speeds.
I looked at the queues and and could not find anything.
Kimmy
Please post your router config, so others can have a look and make suggestions.
Kimmy,
Did you ever resolve this problem? I have similar issue to what you described with iPerf test. So would love to know what you did to fix it.
I have a RB850Gx2 (with 2 x CPU) with 5 x Gig Ethernet ports.
Using iPerf3 test.. between a PC (port 4) and VM on ESX server (port 5) connected on “vlan2”..
My “download” speed seems to approach 850Mbps.. so no complaints here
>iperf3 -c 192.168.12.133 -w 1MB -R
Connecting to host 192.168.12.133, port 5201
Reverse mode, remote host 192.168.12.133 is sending
[  4] local 192.168.12.21 port 57573 connected to 192.168.12.133 port 5201
[ ID] Interval           Transfer     Bandwidth
[  4]   0.00-1.00   sec  87.3 MBytes   733 Mbits/sec
[  4]   1.00-2.00   sec  94.4 MBytes   792 Mbits/sec
[  4]   2.00-3.00   sec  90.6 MBytes   760 Mbits/sec
[  4]   3.00-4.00   sec   101 MBytes   844 Mbits/sec
[  4]   4.00-5.00   sec  95.6 MBytes   802 Mbits/sec
[  4]   5.00-6.00   sec  94.6 MBytes   793 Mbits/sec
[  4]   6.00-7.00   sec  97.2 MBytes   815 Mbits/sec
[  4]   7.00-8.00   sec   102 MBytes   855 Mbits/sec
[  4]   8.00-9.00   sec  99.8 MBytes   837 Mbits/sec
[  4]   9.00-10.00  sec  98.9 MBytes   829 Mbits/sec
But upload is not even half of download speed!
[  4] local 192.168.12.21 port 57836 connected to 192.168.12.133 port 5201
[  4]   0.00-1.00   sec  20.8 MBytes   174 Mbits/sec
[  4]   1.00-2.00   sec  32.9 MBytes   275 Mbits/sec
[  4]   2.00-3.00   sec  30.5 MBytes   256 Mbits/sec
[  4]   3.00-4.00   sec  29.0 MBytes   244 Mbits/sec
[  4]   4.00-5.00   sec  31.0 MBytes   260 Mbits/sec
[  4]   5.00-6.00   sec  30.6 MBytes   257 Mbits/sec
[  4]   6.00-7.00   sec  30.6 MBytes   257 Mbits/sec
[  4]   7.00-8.00   sec  31.1 MBytes   260 Mbits/sec
[  4]   8.00-9.00   sec  29.8 MBytes   250 Mbits/sec
[  4]   9.00-10.00  sec  30.2 MBytes   254 Mbits/sec
During upload.. CPU of the box isn’t exactly maxed out either at only around 23%.. so I can’t see an issue there..
NAME                    CPU        USAGE
ethernet                            3.2%
console                               0%
firewall                              0%
networking                         15.5%
e-mail                                0%
winbox                              0.2%
logging                               0%
management                          0.7%
dhcp                                  0%
profiling                             0%
queuing                               0%
telnet                                0%
bridging                            3.7%
unclassified                          0%
total                              23.3%
I have tried to rule out ESX server being the bottleneck, and test with Macbook Pro. The results are the same.
My router config export can be found here:
http://whereisant.net/misc/export_compact.txt
Any ideas?
Having the same problem. Tested with old RB750GL as well as new RB960PGS.
No other devices connected to the router; just WAN (Fibre 10Mbps 1:1) on ether1 and my laptop on ether2.
Same speed tests on ISP provided Zyxel shows consistent upload speeds of ± 9Mbps.
Same results with all Firewall rules disabled.
My router config is:
jun/02/2018 21:23:02 by RouterOS 6.42.3
software id = 457M-FMZM
model = 960PGS
serial number = 89F908328757
add admin-mac=CC:2D:E0:9D:50:FF auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] comment=WAN
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=sfp1 ] disabled=yes
/interface vlan
add interface=ether1 name=vlan1 vlan-id=699
add comment=defconf name=WAN
add comment=defconf name=LAN
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
/ip hotspot profile
add name=dhcp_pool0 ranges=192.168.1.20-192.168.1.200
add name=dhcp_pool1 ranges=192.168.1.20-192.168.1.200
add address-pool=dhcp_pool1 disabled=no interface=bridge name=dhcp1
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge comment=defconf disabled=yes interface=sfp1
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
set discover-interface-list=discover
add interface=ether2-master list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add interface=sfp1 list=discover
add interface=bridge list=discover
add interface=vlan1 list=discover
add interface=bridge list=mactel
add interface=bridge list=mac-winbox
add address=197.xxx.xxx.xx/30 comment=WAN interface=ether1 network=
197.xxx.xxx.xx
add address=192.168.1.1/24 comment=LAN interface=bridge network=192.168.1.0
add address=192.168.1.0/24 gateway=192.168.1.1
set allow-remote-requests=yes servers=197.xxx.xxx.xx,197.xxx.xxx.xx
/ip dns static
add address=192.168.88.1 name=router.lan
add action=accept chain=input comment=
“defconf: accept established,related,untracked” connection-state=
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
disabled=yes in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid”
connection-state=invalid
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
add action=masquerade chain=srcnat comment=“defconf: masquerade”
ipsec-policy=out,none out-interface=vlan1
add distance=1 gateway=vlan1
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Africa/Johannesburg
/system identity
set name=FRU
/system routerboard settings
set silent-boot=no
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
