Hi
I am currently facing issues with my mikrotik x86 which was installed by my partner isp the configuration is following (Lenovo m71e cpu with 2 Intel Gigabit PCI-E Network Adapter EXPI9301CTBLK and one integrated motherboard realtek rtl8111E gigabit lan , 128gb sata SSD , 8 gb ram , Mikrotik 6.7)
we are using it as pppoe server for 70 client’s, where we provide Symmetrical plan’s to client like (50 Mbps up and 50 Mbps down)
The issue I am experiencing is the bandwidth through (Wan) goes around 920 Mbps download and same with upload which is perfect
But when it comes to (Lan) side the download goes up to 49 Mbps on 50 Mbps plan but the upload doesn’t it goes around 26 or 37 Mbps , we checked with radius everything is ok
New lan card’s where installed tested Broadcom and Intel lan card’s supported but same issue also changed the interface no use
if anyone had a faced such type of issue
