Hi there, I have an issue of Wan upload here.
Speedtests says;
Directly connected to the modem, 500m/30M
RB4011-defconf (barely customized) Show a sesult of 500M/1M@3M while wired… But on Wifi (2 cAP wired to RB4011), I reach max Upload
I am kinda lost as I cannot handle to stream on twitch with stability (1080p should be correct for my available bandwidth)
Please help! And if something’s missing, just ask!
[admin@MikroTik] > /export hide-sensitive
# feb/29/2024 19:19:03 by RouterOS 6.45.1
# software id = AGM2-R7I8
# model = RB4011iGS+
# serial number = B8F40B40D2E3
add admin-mac=C4:AD:34:0A:60:E4 auto-mac=no comment=defconf name=bridge
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.0.10-192.168.0.254
add name=vpn ranges=192.168.89.2-192.168.89.255
add name=dhcp_pool2 ranges=192.168.0.2-192.168.0.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ipv6 dhcp-server
add interface=bridge name=server1
/ppp profile
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1
/interface detect-internet
set detect-interface-list=all internet-interface-list=WAN lan-interface-list=\
LAN wan-interface-list=WAN
/interface l2tp-server server
set enabled=yes use-ipsec=yes
/interface pptp-server server
set enabled=yes
/interface sstp-server server
set default-profile=default-encryption enabled=yes
add address=192.168.0.1/24 comment=defconf interface=bridge network=192.168.0.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add address=192.168.0.0/24 comment=defconf dns-server=8.8.8.8,8.8.4.4 gateway=\
192.168.0.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.0.1 comment=defconf name=router.lan
established,related,untracked
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 protocol=\
udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment="allow pptp" dst-port=1723 protocol=tcp
add action=accept chain=input comment="allow sstp" dst-port=443 protocol=tcp
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
192.168.89.0/24
/ppp secret
add name=vpn
/system clock
set time-zone-name=America/Toronto
/tool mac-server
/tool mac-server mac-winbox
Thanks,
-Damien
