hi all,
I’m using a rb500 with mt router-os v3.0beta7.
It is configured as wlan-accesspoint. therefore eth1&wlan1 are configured as bridge.
the upstream is connected to eth1.
my problem is to shape the upload-speed of the clients which are logged in on interface wlan1
I tried http://wiki.mikrotik.com/wiki/PCQ_Examples but nothing is shaped, here’s my config.:
queue type print
8 name="256_up" kind=pcq pcq-rate=256000 pcq-limit=50 pcq-classifier=src-address,dst-address pcq-total-limit=2000
here is a example queue but it doesn’t work
queue simple print
0 name="queue1" target-addresses=192.168.5.10/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 queue=256_up/wireless-default
limit-at=0/0 max-limit=0/0 total-queue=default-small
do you have any suggestions?
cheers
chris
chris84:
hi all,
queue type print
queue simple print
cheers
chris
Try downgrade to 2.9.42..
/Henrik
Smith
April 19, 2007, 8:18pm
3
Bridge is not the only way to make it work. Try routing, shaping will work, trust me…
Hi Smith,
the problem is that all wlan-accesspoints in our environment are configured as bridge, routing is done by cisco-routers.
does that mean that queues only work in routing-mode?
no you can do traffic shaping in brige mode
try setting the pcq-classifier to just src-address
Smith
April 20, 2007, 8:10pm
6
chris84:
Hi Smith,
I am not sure how shaping works in bridge mode, but generaly speaking bridge is bad. Routing gives you wider bandwidth. it doesn’t matter if you have cisco router, noone stops you to make routing on every MT, and have cisco as main router.
I got it!
here’s the solution:
/interface bridge settings set use-ip-firewall=yes
simple as that
now the queues are working in bridge mode
