The UPnP feature on my 2.8 system does not have some of the features listed in the docs like allow-disable-external-interface and show-dummy-rule. Does that mean I have an older version than is covered in docs?
I find the UPnP does not function with all applications that are suposed to support UPnP either but some do appear to trigger port forwards.
Also I have found simmilar issues with socks proxy. Some applications are fine but others just don’t work with it but do with other types of socks proxies?
It seems to me that UPnP works pretty good in v2.9.
DC++ works, Windows messenger works i think. MSN Messenger finally works. Some do, some dont, UPnP has many “standards” to be a standard.
I wish there was a way for the router to control the amount of polling of statistics that windows does.
Should have done it first really but upgraded to latest 2.8 after paying a new licence but I’m glad I did because now the UPnP feature works fine. It must have been the old version I had was no good. Hopefully some other weird things will be improved.
