uPnP at edge of routed network
Hello everyone
Is it able to make uPnP at mikrotik working if PC is connected to network behind router at local network?
The goal is to allow users from NET1 to access uPnp service at CCR1036.
Multicast routing is enabled at LAN Router now. PIM is activated at CCR1036 on interface that connected to LAN router.
I belive upnp wil only function if the devices is on the same subnet, haven’t tested it myself.
Doing port forwarding on your edge router may be the best thing to do since you are in control of all of the ports
If your router can request the upnp up to the ccr, it should work. But I doubt so. Even ros doesn’t contain upnp client to chain up the requests…
