I using a CCR1036 as main router in my Network with several vlans.
In vlan201 is a synology diskstation with a mediaserver(upnp/dlna) to stream Videos.
I do not realy no alot of dlna, but I’m looking for a way to access dlna mediaserver from other vlans than vlan201.
I’m also not sure which Feature I should use igmp-proxy, pim… in the forum i only found similar things with the result that it is not working with mikrotik??
Is that what I want possible with routeros? Is there any good documentation around?
