I want to try port forward for games and torrent. but after hundred of times failed to port forward i decided to try UPnP but it failed too.
this is my config
# apr/17/2020 18:36:18 by RouterOS 6.43.4
# software id = VZXQ-GKFX
# model = 951Ui-2HnD
# serial number = 43CE02C36EE3
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=FiberStar type=external
add interface=bridge-local type=internal
add action=accept chain=input connection-state=established
add action=accept chain=forward comment="default configuration" \
connection-state=related,new
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface=ether1-gateway
add action=masquerade chain=srcnat comment="default configuration" \
out-interface=ether1-gateway
add action=masquerade chain=srcnat out-interface=FiberStar
i have internet from pppoe connected to router
the upnp use dst address from my pppoe address(100.64.3.126) rather than my public ip. is this normal?
