UPnP; filter rules
Hello
For some reason provider allows me to connect to internet both via pppoe and ethernet.
In upnp settings i have both ether1-gateway and pppoe-out1 interfaces. upnp works fine with pppoe.
If i use ethernet i can see in firewall/nat that ports are opened with 0.0.0.0 as dst.address. online port check shows that these ports are closed.
and even more surprising: if i disable pppoe interface in upnp settings ports are not being opened at all!
Second (a little lame) question. Why do i need to specify ports like 8291 or 80 in Filter Rules to access winbox and webfig respectively, but don’t need to do this for ports opened in firewall/nat tab?
thanks in advance.
