# mar/13/2022 20:59:27 by RouterOS 7.1.3
# software id = 56LU-W8EI
# model = RB4011iGS+
# serial number = B8F40B74C8FF
add admin-mac=C4:AD:34:33:F1:63 auto-mac=no comment=defconf igmp-snooping=yes multicast-querier=yes name=Bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.1.20-192.168.1.254
add add-arp=yes address-pool=dhcp insert-queue-before=bottom interface=Bridge name=defconf
/ipv6 dhcp-server
add address-pool="" interface=Bridge name=server1
/port
set 0 name=serial0
set 1 name=serial1
/queue simple
add burst-limit=0/50M burst-time=0s/5s max-limit=0/50M name="download max" target=ether1
/zerotier
set zt1 comment="ZeroTier Central controller - https://my.zerotier.com/" disabled=yes disabled=yes name=zt1 \
port=9993
add bridge=Bridge comment=defconf interface=ether2
add bridge=Bridge comment=defconf interface=ether3
add bridge=Bridge comment=defconf interface=ether4
add bridge=Bridge comment=defconf interface=ether5
add bridge=Bridge comment=defconf interface=ether6
add bridge=Bridge comment=defconf interface=ether7
add bridge=Bridge comment=defconf interface=ether8
add bridge=Bridge comment=defconf interface=ether9
add bridge=Bridge comment=defconf interface=ether10
add bridge=Bridge comment=defconf interface=sfp-sfpplus1
/ip settings
set icmp-rate-limit=100 rp-filter=loose tcp-syncookies=yes
/ipv6 settings
set accept-router-advertisements=no disable-ipv6=yes
/interface detect-internet
set detect-interface-list=all internet-interface-list=WAN lan-interface-list=LAN wan-interface-list=WAN
add comment=defconf interface=Bridge list=LAN
add address=192.168.1.1/24 comment=defconf interface=Bridge network=192.168.1.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.1.253 client-id=1:f0:9f:c2:76:1b:72 mac-address=F0:9F:C2:76:1B:72 server=defconf
add address=192.168.1.63 client-id=1:70:5a:f:42:a3:d2 mac-address=70:5A:0F:42:A3:D2 server=defconf
add address=192.168.1.74 client-id=1:10:7b:44:4b:46:c8 mac-address=10:7B:44:4B:46:C8 server=defconf
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.1 gateway=192.168.1.1 netmask=24 ntp-server=\
192.168.1.1,132.163.96.1
set allow-remote-requests=yes servers=1.1.1.1
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
/ip firewall address-list
add address=192.168.1.0/24 list=UPnPdevices
add address=192.168.1.0/24 list=allowed_to_router
add action=drop chain=input connection-state=new in-interface-list=WAN protocol=tcp src-port=53
add action=drop chain=input connection-state=new in-interface-list=WAN protocol=udp src-port=53
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related \
disabled=yes hw-offload=yes
add action=accept chain=input in-interface=Bridge src-address=192.168.1.0/24
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
established,related
add action=accept chain=input dst-port=88,3074,53,800,3544,4500,500,1900,8291,37008 protocol=udp
add action=accept chain=input dst-port=3074,80,53,7680,23,5000,8291,2828 protocol=tcp
add action=accept chain=forward dst-port=88,3074,53,800,3544,4500,500,1900,8291,37008 protocol=udp
add action=accept chain=forward dst-port=3074,80,53,7680,23,5000,8291,2828 protocol=tcp
add action=drop chain=input comment="INPUT Drop Invalid" connection-state=invalid log-prefix=\
"invalid connection"
add action=add-src-to-address-list address-list="Port Scanners" address-list-timeout=2d chain=input comment=\
"INPUT Telnet Port Scans" dst-port=23 in-interface=ether1 protocol=tcp
add action=drop chain=input comment="INPUT DROP Rogue VPN Hosts" in-interface=ether1 log=yes log-prefix=\
rogue_vpn_hosts src-address-list=rogue_vpn_hosts
add action=accept chain=input dst-port=500 in-interface=ether1 protocol=udp
add action=accept chain=input dst-port=4500 in-interface=ether1 log=yes log-prefix=who_is_this protocol=udp
add action=accept chain=input in-interface=ether1 protocol=ipsec-esp
add action=accept chain=input in-interface=ether1 protocol=ipsec-ah
add action=accept chain=input comment="INPUT Allow UPnP port 1900 udp" dst-port=1900 log-prefix=UPnP protocol=\
udp src-address-list=UPnPdevices
add action=accept chain=input comment="INPUT Allow UPnP port 2828 tcp" dst-port=2828 log-prefix=UPnP protocol=\
tcp src-address-list=UPnPdevices
add action=accept chain=input comment="INPUT Allow to Router from address list" src-address-list=\
allowed_to_router
add action=accept chain=input comment="INPUT ICMP" protocol=icmp
add action=drop chain=input comment="INPUT DROP ALL"
add action=accept chain=forward comment="FORWARD Accept in IPsec policy" ipsec-policy=in,ipsec
add action=accept chain=forward comment="FORWARD Accept out IPsec policy" ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="FORWARD Accept FastTrack Established, Related" \
add action=accept chain=forward comment="FORWARD Accept Established, Related" connection-state=\
established,related
add action=drop chain=forward comment="FORWARD Drop invalid" connection-state=invalid log-prefix=invalid
add action=drop chain=forward comment="FORWARD Drop incoming from internet which is not public IP" \
in-interface=ether1 log=yes log-prefix=!public src-address-list=not_in_internet
add action=drop chain=forward comment="FORWARD Drop incoming packets that are not NATted" connection-nat-state=\
!dstnat connection-state=new in-interface=ether1 log=yes log-prefix=!NAT
add action=redirect chain=dstnat disabled=yes dst-address=!192.168.1.1 dst-address-list=192.168.1.1 dst-port=53 \
in-interface=!ether1 in-interface-list=!WAN protocol=udp to-ports=53
protocol=tcp to-ports=53
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface-list=WAN \
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=Bridge type=internal
add interface=ether1 type=external
/ipv6 address
add address=fd12:672e:6f65:8899:: interface=Bridge
/ipv6 firewall address-list
/ipv6 firewall filter
established,related
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=\
udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=\
!LAN
/routing igmp-proxy interface
add interface=Bridge upstream=yes
/system clock
set time-zone-name=America/Chicago
/system identity
set name=home
/system logging
add topics=upnp
/system ntp server
set broadcast=yes broadcast-addresses=192.168.1.1 enabled=yes
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set file-name=test streaming-server=192.168.1.74
