Hi, i have enabled upnp, added interfaces and nothing happens programs can’t open ports, i have also tried the ‘upnp test program’ and it fails.. where could be the problem?
add admin-mac=4C:5E:0C:43:AC:86 auto-mac=no disabled=yes name=bridge-local
add admin-mac=4C:5E:0C:43:AC:89 auto-mac=no l2mtu=1598 name=bridge_lan
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether6 ] name=ether6-master-local
set [ find default-name=ether7 ] master-port=ether6-master-local name=
ether7-slave-local
set [ find default-name=ether8 ] master-port=ether6-master-local name=
ether8-slave-local
set [ find default-name=ether9 ] master-port=ether6-master-local name=
ether9-slave-local
set [ find default-name=ether10 ] master-port=ether6-master-local name=
ether10-slave-local
/ip neighbor discovery
set ether1-gateway discover=no
/interface vlan
add disabled=yes interface=ether2 name=vlan1 vlan-id=10
add disabled=yes interface=ether2 name=vlan2 vlan-id=20
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
add name=dhcp_lan_pool ranges=192.168.10.100-192.168.10.200
add name=dhcp_wlan_pool ranges=192.168.20.100-192.168.20.200
add name=vpn_pool ranges=192.168.30.100-192.168.30.200
add address-pool=default-dhcp interface=bridge-local name=default
add address-pool=dhcp_lan_pool disabled=no interface=bridge_lan name=dhcp_lan
add address-pool=dhcp_wlan_pool disabled=no interface=wlan1 name=dhcp_wlan
add bridge=bridge_lan interface=ether3
add bridge=bridge_lan interface=ether4
add bridge=bridge_lan interface=ether5
add bridge=bridge-local disabled=yes interface=ether6-master-local
add bridge=bridge-local disabled=yes interface=sfp1
add bridge=bridge_lan interface=ether2
add disabled=yes ports=ether2,switch1-cpu switch=switch1 vlan-id=10
add disabled=yes ports=ether3,switch1-cpu switch=switch1 vlan-id=20
add address=192.168.88.1/24 comment=“default configuration” disabled=yes
interface=wlan1 network=192.168.88.0
add address=192.168.10.1/24 interface=bridge_lan network=192.168.10.0
add address=192.168.20.1/24 interface=wlan1 network=192.168.20.0
/ip dhcp-client
add comment=“default configuration” dhcp-options=hostname,clientid interface=
ether1-gateway
add address=192.168.10.0/24 comment=lan gateway=192.168.10.1
add address=192.168.20.0/24 comment=wlan gateway=192.168.20.1
add address=192.168.88.0/24 comment=“default configuration” gateway=
192.168.88.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.88.1 name=router
add address=192.168.1.1 name=gw
add chain=input comment=“default configuration” protocol=icmp
add chain=input comment=“default configuration” connection-state=established
add chain=input comment=“default configuration” connection-state=related
add action=drop chain=input comment=“default configuration” in-interface=
ether1-gateway
add chain=forward comment=“default configuration” connection-state=
established
add chain=forward comment=“default configuration” connection-state=related
add action=drop chain=forward comment=“default configuration”
connection-state=invalid
add action=drop chain=input dst-port=22 in-interface=pppoe-out1 protocol=tcp
add action=drop chain=input dst-port=23 in-interface=pppoe-out1 protocol=tcp
add action=drop chain=input dst-port=21 in-interface=pppoe-out1 protocol=tcp
add action=drop chain=input dst-port=80 in-interface=pppoe-out1 protocol=tcp
add action=masquerade chain=srcnat comment=“default configuration” disabled=
yes out-interface=ether1-gateway
add action=masquerade chain=srcnat out-interface=pppoe-out1
add action=masquerade chain=srcnat out-interface=“(unknown)”
/ip traffic-flow
set enabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge_lan type=external
add interface=wlan1 type=external
You have no upnp interfaces define as internal.
I have defined bridge_lan and wlan1 as internal and pppoe-out as external, same issue.. what i am missing?
When things “should” be working what happens when you issue “/ip firewall nat print dynamic” ?
On what interface the machine are attached?
You sure the device connected at routerboard are configured for UPnP?
You have other devices, like other router, with UPmP attached?
I don’t have any other router in my network, i have used the ‘upnp test program’ and it fails, pppoe-out is the external interface and bridge_lan(laptop from which i have tested is connected through this) + wlan1 internal
[admin@MikroTik] > /ip firewall nat print dynamic
0 D chain=dstnat action=dst-nat to-addresses=192.168.10.100 to-ports=26421
protocol=tcp dst-address=192.168.20.1 dst-port=26421
1 D chain=dstnat action=dst-nat to-addresses=192.168.10.100 to-ports=26421
protocol=udp dst-address=192.168.20.1 dst-port=26421
2 D chain=dstnat action=dst-nat to-addresses=192.168.10.100 to-ports=5058
protocol=tcp dst-address=192.168.20.1 dst-port=5058there is something wrong here since 192.168.20.1 is the gateway address for wlan1
Make sure there is only one type external defined in your upnp config
Sent from my Nexus 7 using Tapatalk
Yes, pppoe-out is set as external and bridge_lan + wlan1 internal..
