Hi Guys,
I have a NAS that has about 145 dynamic NAT rules it want to use for remote access.
I turned on UPnP and it did create the NAT rules but now I want to turn it off and go through each rule manually.
Is there anyway to make a rule static or export the rules? If I turn off UPnP they will be removed. I copied the terminal screen to capture them and I guess I could go through and turn it into script but I was wondering if anyone else has run into this before?
Thanks!
