UPnP not working
I'm trying to get UPnP working but my torrent client reprots the listening port for incoming connections to be closed at all time.
I have tried to disable the software firewall so what is left is the mikrotik 3011.
I do not know what is wrong....
jun/09/2021 17:06:41 by RouterOS 6.48.3
software id = E66J-P7EA
model = RouterBOARD 3011UiAS
add admin-mac=XXXXXXXXXXauto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas
sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp1
set discover-interface-list=none
add address=192.168.88.1/24 comment=defconf interface=bridge network=
192.168.88.0
/ip cloud
set update-time=no
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
/ip dhcp-server lease
add address=192.168.88.254 mac-address=70:8B:CD:56:03:05 server=defconf
add address=192.168.88.0/24 comment=defconf dns-server=1.1.1.1 gateway=
192.168.88.1
set servers=1.1.1.1
/ip dns static
add address=192.168.88.1 name=router.lan
add address=1.1.1.1 disabled=yes name=cloudflairDNS
/ip firewall address-list
add address=192.168.88.2-192.168.88.254 list=allowed_to_router
add address=0.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=172.16.0.0/12 comment=RFC6890 list=not_in_internet
add address=192.168.0.0/16 comment=RFC6890 list=not_in_internet
add address=10.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=169.254.0.0/16 comment=RFC6890 list=not_in_internet
add address=127.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=224.0.0.0/4 comment=Multicast list=not_in_internet
add address=198.18.0.0/15 comment=RFC6890 list=not_in_internet
add address=192.0.0.0/24 comment=RFC6890 list=not_in_internet
add address=192.0.2.0/24 comment=RFC6890 list=not_in_internet
add address=198.51.100.0/24 comment=RFC6890 list=not_in_internet
add address=203.0.113.0/24 comment=RFC6890 list=not_in_internet
add address=100.64.0.0/10 comment=RFC6890 list=not_in_internet
add address=240.0.0.0/4 comment=RFC6890 list=not_in_internet
add address=192.88.99.0/24 comment="6to4 relay Anycast [RFC 3068]" list=
not_in_internet
add action=accept chain=input comment=
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
add action=drop chain=input comment="defconf: drop all not coming from LAN"
in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
"defconf: accept established,related, untracked" connection-state=
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
add action=accept chain=input comment="default configuration"
add action=accept chain=input src-address-list=allowed_to_router
add action=fasttrack-connection chain=forward comment=FastTrack
add action=accept chain=forward comment="Established, Related"
add action=drop chain=forward comment="Drop invalid" connection-state=invalid
log=yes log-prefix=invalid
"Drop tries to reach not public addresses from LAN" dst-address-list=
not_in_internet in-interface=bridge log=yes log-prefix=!public_from_LAN
out-interface=!bridge
"Drop incoming packets that are not NATted" connection-nat-state=!dstnat
connection-state=new in-interface=ether1 log=yes log-prefix=!NAT
"Drop incoming from internet which is not public IP" in-interface=ether1
log=yes log-prefix=!public src-address-list=not_in_internet
"Drop packets from LAN that do not have LAN IP" in-interface=bridge log=
yes log-prefix=LAN_!LAN src-address=!192.168.88.0/24
add action=masquerade chain=srcnat comment="defconf: masquerade"
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh address=192.168.88.0/24 disabled=yes
set api disabled=yes
set winbox address=192.168.88.0/24
set api-ssl disabled=yes
/ip ssh
set forwarding-enabled=remote strong-crypto=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=ether1 type=external
add interface=bridge type=internal
/lcd
set time-interval=hour
/system clock
set time-zone-name=Europe/Stockholm
/system script
add dont-require-permissions=no name=releaseIPonWan owner=johannes policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=
"/ip dhcp-client\r
\nrelease 0\r
\nset 0 disabled=yes"
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
The reason it’s not working is you’re dropping anything from LAN destined towards 224.0.0.0/4 (multicast).
Use this instead:
http://forum.mikrotik.com/t/is-my-firewall-config-up-to-date-with-current-ietf-spec-ipv4-ipv6/146699/1
sorry but my mikrotik knowledge is a little rusty, I did the setup some 4 or 5 years ago and have not been configuring anything for that time.
What do would you like me to change for it to work?
I see that you added drop multicast in “Drop tries to reach not public addresses from LAN” and “defconf: drop non global from WAN”… well I do not really understand how your rules work and my memory is foggy :wink:
Copy/Paste my entire configuration. Just make changes to lan_subnets address list to match your own local environment.
