I’m using RB750 with firmware 2.38
I configured the UPnP and it worked. Bitttorrent managed to dynamically add the port forwarding rules.
Unfortunately I had the bad idea to remove the NAT rules by hand. After this the UPnP isn’t working right.
Of course I tried to solve it by remaking the UPnP settings, by restarting the device, but with no results.
Windows detects the device and that’s all.
I tested with “UPnp Test Program” and it fails to get the external IP address, so the NAT rules can’t by set anymore. I attached the Wireshark capture.
There’s any solution for this issue?
Other that rolling back the settings.
Thank you!
