I set up UPNP on internet gateway mikrotik, and it works fine with clients that are in same broadcast domains, but its not working with client on another subnet .. .
Is it possibile to acomplish or it cant be done ?
somebody ?
please
Please, is this not a beginner Q?
Im trying to set UPNP to work over multiple subnets, that have one def gateway to the internet, so I dont have to manually forward ports to users on the gateway MT, I want UPNP to do that
pleeeease
but the main idea of upnp is to add automatic nat rule. there is no use for that if the machine is not directly connected to the same network …
yes, idea is to add dst-nat rule.
So I thought it can do that for computers that are not directly connected to that network.
But ok, thx for the answer, so I dont bother me and you with UPNP
