zervan
June 22, 2012, 12:09pm
1
Situation:
internet-> router A <-LAN-A-> router B <-LAN-B
Router A is doing NAT. When I enable UPnP on it (external interface is going to internet, internal interface is LAN-A), it is working well from LAN-A.
But there is another router B, which is doing simple routing (no NAT). Is it possible to get UPnP working from LAN-B to internet?
Dobby
June 22, 2012, 4:44pm
2
Deleted because not related.
zervan
June 22, 2012, 5:21pm
3
Yes Dobby, you are right. I use port forwarding for some applications, but it would be great if user could use any UPnP application without my intervention.
Dobby
June 22, 2012, 6:28pm
4
Dobby
June 25, 2012, 10:50am
5
