I have the following setup:
PC-MT-Vigour2600we.
I want to use upnp.
pc-vigor works
pc-mt-vigor does not.
The mt appears as a gateway and forwarding rules appear but not traffic appears in them and the sw on the pc reports as sill been firewalled.
Is what I am trying to do (pass upnp though 2 devices?) possiable?
As an alternative I thought I might use the vigour as a modem rather than a router using its PPPoE pass-though for wired lan seting. Can this be done and what would I need to set up in MT?
I am using 2.8.13.
Many thanx for any pointers.
Paul
PS this is following on from http://forum.mikrotik.com//viewtopic.php?t=4910&highlight= 95K rules.
Cannot up date this as now locked:
Results for 3k or 6k rules (cannot rem which) it took 1 hr to add these rules via loading them as a filter chain from a text file I created and then loaded as if it was a backup.
This was on a ppro 200 1mg cache.
So I decided to run peerguardian on a XP box as so:
pc-xp(peerguardian)-mt-vigor.
However for the upnp testing I have removed xp(peerguardin) to keep it simple.
