Is there, or will there be, any support for UPS in 2.9?
Thanks.
Thanks.
you mean ‘/system ups’?
Edgars
Maybe he meant, “…for the Routerboard 532”. I would like to see this, also…
Hitek
It was already posted in the forum that you should write to support to get an ups package for the RB5xx if you need one.
Thanks, Cmit… I haven’t needed to use it yet, so I hadn’t gone looking for it. I just noticed it was missing… ![]()
Thanks for the replies.
Yes, I did mean UPS support for 2.9 running on RB532. I will write to support.
Any idea why this is not included as standard?
I have found this package is now availble from MT’s web site:
http://www.mikrotik.com/download_rb500rc.html
'Still don’t understand why it is seperate. Sadly, I also note there appears to be no SMTP support for a UPS. I have emailed support with this feature request.
