I need a firewall filter, or any other method to deny access to root ip of router running “user manager”. but allow
the userman section of it as following:
deny: http://Router_IP_address/
allow: http://Router_IP_address/userman
thx
thx
I think you can’t.
Why you need to do this? I can make a blank html for your http://ip if you like. It will be accessible, but blank ; D!
OK, on what directory the index html page located?
thanks,
You have to change it via a special package..
explain please how to do that?
If you need to do that, please, send me an email..
These are files we use to make this.
Download these files and move to /files in WinBox. Reboot the router and you will have your http://IP web in blank and you will have access to usermanager as usually.
WairLink_web_in_blank_4.15.dpk (3.79 KB)
WairLink_web_in_blank_3.30.dpk (3.8 KB)
WairLink_web_in_blank_4.10.dpk (3.8 KB)
Its better if you use the same version. You could try all three. When you reboot the router, you will see the result in /log.
thanks.
mine is 4.13 - and your 4.10 did it well.
you deserve a very good looking KARMA ![]()
thanks many times –
Thanks ; )
Yes, I need it to.
Can i use your files on RouterOS versions 4.17 and 5.4 ?
P.s I am using RB433
I also want to:
deny access to HTTPS://router
Allow access to HTTPS://router/usermanager
Thank a lot
Sure. Test it ; )
Is it also possible to put a custom website to main router page? Instead of the mikrotik default page?
it works on 5.5 also!
yes, if you are a mikrotik distributor, you can email mikrotik to get access to the branding package creator.
hello,
i use dpk file and now how i can revert this change?
i have problem with this change and cant revert this!!??
Backup config, netinstall the board and restore backup.
i test it but net install not work for this!
can you create a package with automatic redirection to http://router_IP_Address:www_port/umfiles/sample_name.htm
for sample: http://172.16.21.70:809/umfiles/price.htm
i can upload my custom htm page in /umfiles/ directory.
tank for youre help.
Not posible.
Note that is not 2 minutes to generate new one and return to mine again.. : P!
Not posible what?
create package,redirecting in html,find router ip and port or answer to me?
i request a way to change to my default web page and you answer it.i try and its not work!
i hope you can help mikrotik users that chek this toptik each day for frist time to find a new Solution in mikrotik and post new request
im sorry for youre time & my bad english translate
Can you explain the way you did the netinstall? This reinstalls ALL the filesystem… then… also rebuild the original dpk file..
It’s like format a PC with windows and say that your background image is still there.. : P!
