Urgent help please
Hello! Here's the thing: I connected WAN (public IP) to MT and forwarded port 80 through NAT to my webserver, which has a local IP address (as presented here: RouterOS - RouterOS - MikroTik Documentation ). Works like a charm, but when I look into my server's log, there is only one source IP for all the connections, and that is MT's IP. Is there a way to forward port 80 AND have the real IPs of users who visit my site?
/ip address print detail
0 ;;; added by setup
address=46.45.xxx.xxx/27 network=46.45.xxx.xxx interface=WAN actual-interface=WAN
1 address=192.168.99.131/24 network=192.168.99.0 interface=Local actual-interface=Local
2 address=178.211.99.11/27 network=178.211.99.0 interface=WAN actual-interface=WAN
/ip route print detail
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
0 A S ;;; added by setup
dst-address=0.0.0.0/0 gateway=46.45.xxx.xxx gateway-status=46.45.xxx.xxx reachable via WAN distance=1 scope=30 target-scope=10
1 S ;;; added by setup
2 ADC dst-address=46.45.xxx.xxx/27 pref-src=46.45.xxx.xxx gateway=WAN gateway-status=WAN reachable distance=0 scope=10
3 ADC dst-address=178.211.99.0/27 pref-src=178.211.99.11 gateway=WAN gateway-status=WAN reachable distance=0 scope=10
4 ADC dst-address=192.168.99.0/24 pref-src=192.168.99.131 gateway=Local gateway-status=Local reachable distance=0 scope=10
/interface print detail
0 R name="Local" default-name="ether4" type="ether" mtu=1500 mac-address=00:50:56:AD:25:01 fast-path=no
1 R name="WAN" default-name="ether1" type="ether" mtu=1500 mac-address=00:50:56:AD:47:9D fast-path=no
2 X name="eth2" default-name="ether3" type="ether" mtu=1500 mac-address=00:50:56:AD:11:E0 fast-path=no
3 X name="sozlukbu" default-name="ether2" type="ether" mtu=1500 mac-address=00:50:56:AD:42:99 fast-path=no
/ip firewall export"
add chain=forward protocol=tcp
add action=dst-nat chain=dstnat dst-address=178.211.99.11 dst-port=80 protocol=tcp to-addresses=192.168.99.251 to-ports=80
Use hairpin nat
http://wiki.mikrotik.com/wiki/Hairpin_NAT
This is not the solution. Please understand my request.
The client receives the reply packet it expects, and the connection is established.
However, the web server only ever sees a source IP address of 192.168.1.1 for all requests from internal clients regardless of the internal client's real IP address. There is no way to avoid this without either using a router that can do application level DNS inspection and can rewrite A records accordingly, or a split DNS server that serves the internal clients the internal server IP address and external clients the external server IP address.
This is called - among other terms - hair pin NAT because the traffic flow has clients enter the router through the same interface it leaves through, which when drawn looks like a hair pin.
Please help. I’ waiting..
The following rule:
should only be applied to traffic leaving your WAN interface - i.e. add an out-interface selection to it. At the moment it is masquerading all traffic which is causing your problem.
…and don’t cross post. I will not respond to the other post from now on.
Mikrotik was re-established and configured. A clean installation. All information is as follows,
[memolipascal@MikroTik]  /ip firewall filter print
 0   chain=forward action=accept protocol=tcp dst-port=80
[memolipascal@MikroTik]  /ip route print
        0.0.0.0/0                          46.45.169.97              1
 1 ADC  46.45.169.96/27    46.45.169.123   WAN                       0
 2 ADC  178.211.39.0/27    178.211.39.11   mywebsite                 0
 3 ADC  192.168.99.0/24    192.168.99.50   LAN                       0
[memolipascal@MikroTik] /ip address print
 #   ADDRESS            NETWORK         INTERFACE
     46.45.169.123/27   46.45.169.96    WAN
 1   ;;; Local IP
     192.168.99.50/24   192.168.99.0    LAN
 2   ;;; my website IP sozlukbu.com
     178.211.39.11/27   178.211.39.0    mywebsite
[memolipascal@MikroTik] /ip firewall nat> print
 0   chain=srcnat action=masquerade
 1   chain=dstnat action=dst-nat to-addresses=192.168.99.251 protocol=tcp dst-address=!192.168.99.0/24 dst-address-type=local dst-port=80
 2   chain=dstnat action=dst-nat to-addresses=192.168.99.251 to-ports=80 protocol=tcp dst-address=178.211.39.11 dst-port=80
Same issue. Specify the out-interface as your WAN interface in this rule:
If you need hairpin NAT make sure that you properly constrain the masquerade rule so that it doesn’t affect traffic from the WAN side.
 0   chain=srcnat action=masquerade out-interface=WAN
Like this? Now the website does not work.
chain=srcnat action=masquerade out-interface=mywebsite
This works fine but. The same problem. Please see : http://www.sozlukbu.com/test.aspx
Visit IP : 192.168.99.50
Which version ROS are you using?
Which physical interface is WAN?
Which physical interface is mywebsite?
What is this dstnat for? I would remove it.
edit: You should post “/ip firewall filter” also. I can’t even ping that ip.
You seem to have 2 ISP connections. You need to masquerade traffic leaving those but not the traffic going to your LAN. You may also have to use some mangle rules to mark connections from each ISP and ensure the traffic is returned correctly.
Post your entire config - output from /export compact.
Version : MikroTik RouterOS 6.0
This a virtual server. (On the Vmware ESX 5) and virtual network device. (WAN and mywebsite devices)
[memolipascal@MikroTik] /ip firewall filter> print
[memolipascal@MikroTik] > ping 192.168.99.251
HOST                                     SIZE TTL TIME  STATUS
192.168.99.251                             56 128 0ms
[memolipascal@MikroTik] > /export compact
# feb/08/2014 15:49:30 by RouterOS 6.0
set 0 name=LAN speed=1Gbps
set 1 mac-address=00:50:56:31:A4:F0 name=WAN
set 2 speed=1Gbps
set 3 name=mywebsite speed=1Gbps
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m mac-cookie-timeout=3d
/port
set 0 name=serial0
set 1 name=serial1
add address=46.45.169.123/27 comment="added by setup" interface=WAN network=46.45.169.96
add address=192.168.99.50/24 comment="Local IP" interface=LAN network=192.168.99.0
add address=178.211.39.11/27 comment="my website IP sozlukbu.com" interface=mywebsite network=178.211.39.0
add chain=forward dst-port=80 protocol=tcp
add action=masquerade chain=srcnat out-interface=LAN
add action=dst-nat chain=dstnat dst-address=!192.168.99.0/24 dst-address-type=local dst-port=80 protocol=tcp to-addresses=192.168.99.251
add action=dst-nat chain=dstnat dst-address=178.211.39.11 dst-port=80 protocol=tcp to-addresses=192.168.99.251 to-ports=80
add comment="added by setup" distance=1 gateway=46.45.169.97
This is exactly what you don’t want!
If you masquerade traffic leaving the LAN interface it changes the SRC IP address in the IP header (to the router’s IP address).
Masquerade the traffic leaving the ISP interfaces - not the traffic leaving the LAN interface,
Sorry I do not understand. Do exactly what is required.
add action=masquerade chain=srcnat out-interface=WAN
Whichever, it is necessary to use?
You seem to have 2 ISP connections - the interface you call “WAN” and the interface you call “mywebsite”. These should both be masqueraded. The LAN interface should not be masqueraded.
# feb/08/2014 17:40:33 by RouterOS 6.0
/port
set 0 name=serial0
set 1 name=serial1
add address=178.211.39.11/27 interface=WAN network=178.211.39.0
set allow-remote-requests=yes servers=195.175.39.39
add comment="added by setup" distance=1 gateway=178.211.39.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
Has been restructured. But the same problem. I think it is not a solution MikroTik.
That config should not cause the public IPs to be hidden from the web server. Make sure that you have cleared your browser cache before testing.
To avoid confusion I suggest that you update to ROS 6.9 - the export seems to from 6.0 .
Sorry. Same problem. (6.9) Not a solution to this?
[admin@MikroTik] > /export compact
# feb/09/2014 13:48:47 by RouterOS 6.9
# software id = 731M-816R
set [ find default-name=ether2 ] name=LAN speed=1Gbps
set [ find default-name=ether1 ] name=WAN speed=1Gbps
/port
set 0 name=serial0
set 1 name=serial1
add address=178.211.39.11/27 comment="added by setup" interface=WAN network=178.211.39.0
add address=192.168.99.50/24 interface=LAN network=192.168.99.0
/ip service
/ip upnp
set allow-disable-external-interface=no
With this code, the website is running. But, visitor IP : 192.168.99.50
But, With this code, the website is not running.
Please help.
