“Rate-limitation is configured in the following form [rx-rate[/tx-rate] [rx-burst-rate[/tx-burst-rate] [rx-burst-threshold[/tx-burst-threshold] [rx-burst-time[/tx-burst-time] [priority] [rx-rate-min[/tx-rate-min]]]]. For example, to set 1M download, 512k upload for the client, rate-limit=512k/1M”
Thanks but im still abit confuse…below is my details of hotspot if can just tell me where to make changes eg: 128k up/384k down 192k up/512k down
to limit clients to a fix upload & download rate
im running a 4MB unshaped dsl line, but my isp has restrictions for example 1st & 2nd priority…meaning if im using torrent i get full speed unshaped but the rest on my network get 50% of the actual line speed thats why i want to set everything evenly…
my hotspot clients i just want to give internet access with low download rate and fast upload
The settings i mark red will limit your entire bandwidth to 128k/384k, if your intention is for single user, remove that and leave it blank for unlimited.
The red need attention! default should be the profile name, share user should be = 1, rate limit is ok but means not burstable. when creating the, specify the profile name in the group.
