urgent help
Since the internet connection has been cut off and all tunnels and ways in mikrotik has been disabled by the regime, in order to stop their crime we need an emergency access to the v2ray feature( shadowsocks , vmess , trojan ) in routeros to use as a main way to pass internet disconnection and connect our people to abroad.
thanks
mikrotik has no such shadowsocks feature, but there are plenty of other interesting solutions, like wireguard, zerotier, DNS over HTTPS etc.
«emergency access to the shadowsocks feature in routeros»???
RouterOS do not have any “shadowsocks feature”
Can they also block ICMP tunnels and SSTP tunnels?
dear normis ,iknow mikrotik no such shadowsocks feature , please added , dns over http , zerotier , wireguard blocked in iran
how icmp tunnel with mikrotik?
sstp tunnel just work in local islamic regime network like noth korea network , to internet gateway not working
mikrotik is simple can server runing in one minute in vps ,
The Iranian government blocks for 2 hours after runing vps
But if you keep writing here means that somehow you are on Internet from Iran by “BFA”…
stop tracking me !!! please edit my isp soon as possible ، icreate vps and connect with rdp to send message
how about NordVPN?
not working
edit my isp ......
edit my isp name :name_badge:
not sure what u mean by edit my isp
rextended show my vps provider
just a few ideas:
BR
W
openvpn 443 , sstp already blocked ‌‌, install and configure openwrt for normall people is very hard , routeros simple , fast ‌‌ , please add shadowsocks in ros
Even if, by hypothesis, it was at least considered, it would take months to integrate it.
@soheilsh
do not revert @Normis change on topic title.
And thanks for the “idiot”, nobody understood that you are in Iran…
@soheilsh
u should know one thing, u do not need to watch on the name of the VPN, u should focus on which port /protocol they are operaithing
e.g. Shadowsocks uses the port 443 same as SSTP , also OVPN can wotk on 443 tcp/udp.
i will spend digging on the log, rather than asking add please add shadowsocks in ros
I hope you know, that like me, most people are just simple MT users here, you (and your friends) should be probably trying to contact MT directly.
Sorry if my suggestions didn´t help much, that´s all I got.
W
@woland: Noticed.
