I am trying to install the Dude in Windows 10 and It does not work… I install it and when I open the programme and I try to connect my Routerboard RB411AH it shows this error: Connect failed 10061
I don’t understand well the steps in MikroTik wiki.. Can anybody help me?
ams16,
- What version of the Dude do you use?
- To which port do you trying to connect?
Similar situation is mentioned here: Dude fresh install doesn’ connect
Thank you!
If you would like to run the dude as a server on windows you are out of luck. Windows is only supported as a dude client anymore.
You can install dude server on many mikrotik though.
Makes way more sense anyway.
That’s wrong. OP cannot install The Dude server on his/her RB411AH, for instance, since this board is MIPSBE, whereas The Dude server is only supported on Tile, ARM, x86 (including CHR) and MMIPS.
Ok sorry, on „many“ mikrotiks it is.
