URGENT! Mikrotik lost wds connection and can't reconnect.
I have problem with mikrotik (tested the newest 2.6.38).
Mikrotik lost connection in peer-to-peer wds link:
lan --RB532 A(station-wds + nstreme)------(bridge + nstreme)RB532 B—lan
.. and can’t stable connect again (watchdog is running and restarting both rb532).
In log RB532 A i have (i can’t log to RB532 B):
– cut –
00:02:33 wireless,info 00:0B:6B:4F:A9:D9@dzialdowo-plosnica: failed to connect, join timeout
00:02:45 wireless,info 00:0B:6B:4F:A9:D9@dzialdowo-plosnica: failed to connect, join timeout
00:02:57 wireless,info 00:0B:6B:4F:A9:D9@dzialdowo-plosnica: failed to connect, join timeout
00:03:09 wireless,info 00:0B:6B:4F:A9:D9@dzialdowo-plosnica established connection on 5560, SSID komin-plosnica
00:03:14 wireless,info 00:0B:6B:4F:A9:D9@dzialdowo-plosnica: lost connection, extensive data loss
00:03:15 wireless,info 00:0B:6B:4F:A9:D9@dzialdowo-plosnica: failed to connect, join timeout
00:03:27 wireless,info 00:0B:6B:4F:A9:D9@dzialdowo-plosnica established connection on 5560, SSID komin-plosnica
00:03:36 wireless,info 00:0B:6B:4F:A9:D9@dzialdowo-plosnica: lost connection, extensive data loss
00:03:36 wireless,info 00:0B:6B:4F:A9:D9@dzialdowo-plosnica: failed to connect, join timeout
00:03:48 wireless,info 00:0B:6B:4F:A9:D9@dzialdowo-plosnica established connection on 5560, SSID komin-plosnica
00:04:02 wireless,info 00:0B:6B:4F:A9:D9@dzialdowo-plosnica: lost connection, extensive data loss
00:04:03 wireless,info 00:0B:6B:4F:A9:D9@dzialdowo-plosnica: failed to connect, join timeout
00:04:15 wireless,info 00:0B:6B:4F:A9:D9@dzialdowo-plosnica: failed to connect, join timeout
00:04:27 wireless,info 00:0B:6B:4F:A9:D9@dzialdowo-plosnica: failed to connect, join timeout
00:04:39 wireless,info 00:0B:6B:4F:A9:D9@dzialdowo-plosnica: failed to connect, join timeout
00:04:51 wireless,info 00:0B:6B:4F:A9:D9@dzialdowo-plosnica: failed to connect, join timeout
00:05:12 wireless,info 00:0B:6B:4F:A9:D9@dzialdowo-plosnica established connection on 5560, SSID komin-plosnica
00:05:16 wireless,info 00:0B:6B:4F:A9:D9@dzialdowo-plosnica: lost connection, extensive data loss
00:05:16 wireless,info 00:0B:6B:4F:A9:D9@dzialdowo-plosnica: failed to connect, join timeout
00:05:28 wireless,info 00:0B:6B:4F:A9:D9@dzialdowo-plosnica: failed to connect, join timeout
00:05:41 wireless,info 00:0B:6B:4F:A9:D9@dzialdowo-plosnica: failed to connect, got deauth: class 2 frame received (6)
– cut –
I had this problem few months ago and hard restart of both devices solved problem but now i cant physically go to that localization.
please make the support output files and send them to support@mikrotik.com
