Ok, tried everything I could. I don’t know how to work this around.
pppoeout connection to the DSL modem gives me the IP address:
219.89.126.xxx
default gateway route auto assigned: 222.155.64.1 - which turns to be unreachable
I can’t ping nor access from outside world. However if I make a PPPoE connection on windows, it just works fine with the same IP addresses.
Apparently it’s a linux issue with the gateway being on a different subnet. How can I work this around?
Please help, I’m trying this for about a month now with no luck.
the default route for PPPoE shows as unreachable at winbox routing table:
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 10.0.0.2 5
1 A S 0.0.0.0/0 192.168.3.1 5
2 A S 0.0.0.0/0 202.174.163.254 1 3 DS 0.0.0.0/0 222.155.64.1 2this shows as unreachable at winbox
4 S 0.0.0.0/0 10.0.0.2 5
5 S 0.0.0.0/0 192.168.3.1 10
and public ip address 219.89.126.xxx created by PPP connection is unreacheable from a remote machine on the internet. (can’t ping).
However when I set the modem to be the PPPoE or windows, I can ping from external internet.
PS: Tried to untick “Add default route” on Dial Out with no luck
Long time since I’ve mucked around with PPP, but since PPP is a Point-to-Point Protocol, it doesn’t actually require IP addresses on either end of the connection. Since the route provided by the PPP server isn’t on the same subnet as the IP provided, MT says it’s unreachable. So, ignore that route and do one for yourself:
