Urgent, Need help i messed up the Mikrotik login page structure
So i was logged in using winbox in the router and i was on the files section and suddenly some loading windows popped up (maybe because i mis clicked something), i got surprized and clicked on the undo button the winbox have then suddenly a flash rv etc folder and files started to get created each time i clicked on the undo button up until now in the process of solving the issue i even more messed up the file structure and now the login page is not working properly.
AS U CAN SEE IN THE PHOTO WHAT IS SHOULD DO NOW
image link: https://imgur.com/a/L7Al9Ia
I guess you can try to factory reset your router, not sure whether that will fix it though.
So, let me get this straight, you probably have a hacked router, and then want us to click on an URL////// Not bloody likely.
Disconnect from internet, and then netinstall a fresh firmware and for gods sake dont make any changes to the config before checking here first.
And dont use the same username and password as used previously
nooo i used an external image hosting in order to show the image because when i tried using the attach option it gaved me an error the router is not hacked and this happened when i clicked on the undo button
