Here is my setup in my CCR1009-7G-1C-1S+. The problem is that users behind Lan bridge experiencing unstable data download and upload. Sometimes the users test bandwidth and get 15Mbs and sometime get 3Mbs. Please note that
- at the time that users report the problem total bandwidth through WAN1-3 in total still have very large room for much more bandwidth.
- I have tried to limit user speed, but user have reported a much worst speed and lag.
Port1-3: WAN1-3 (WAN1 = 200Mbs, WAN2 = 200Mbs, WAN3 = 50Mbs)
Port4,5 (bridge1): Lan (through hotspot authen)
Port6,7 (bridge2): Lan (no authen needed)
Would you please take a look at my setting below to see if I miss anything.
#RouterOS 6.39.2
add arp=reply-only comment="bridge1: ether 4-5 as HOTSPOT" name=bridge1
add arp=reply-only comment="bridge2: ether 6-7 as LAN" name=bridge2
set [ find default-name=ether1 ] name=ether1-WAN
set [ find default-name=ether2 ] name=ether2-WAN
set [ find default-name=ether3 ] name=ether3-WAN
set [ find default-name=ether4 ] name=ether4-HOTSPOT
set [ find default-name=ether5 ] name=ether5-HOTSPOT
set [ find default-name=ether6 ] name=ether6-LAN
set [ find default-name=ether7 ] name=ether7-LAN
/ip firewall layer7-protocol
add name=layer7-bittorrent-exp regexp="^(\\x13bittorrent protocol|azver\\x01\$\
|get /scrape\\\?info_hash=get /announce\\\?info_hash=|get /client/bitcomet\
/|GET /data\\\?fid=)|d1:ad2:id20:|\\x08'7P\\)[RP]"
/ip hotspot profile
add dns-name=wifi.com hotspot-address=10.10.10.1 login-by=\
http-chap,mac-cookie name=HOTSPOT use-radius=yes
/ip hotspot
add disabled=no idle-timeout=4h interface=bridge1 name=hotspot1 profile=\
HOTSPOT
/ip hotspot user profile
add !idle-timeout keepalive-timeout=1d name=unlimited_user shared-users=\
unlimited transparent-proxy=yes
add !idle-timeout keepalive-timeout=1d name=shared1user shared-users=1 transparent-proxy=yes
add name=pool_HOTSPOT ranges=10.10.10.2-10.10.10.254
add name=pool_LAN ranges=10.10.20.2-10.10.20.254
add add-arp=yes address-pool=pool_HOTSPOT authoritative=after-2sec-delay \
disabled=no interface=bridge1 lease-time=1d name=HOTSPOT_dhcp
add add-arp=yes address-pool=pool_LAN authoritative=after-2sec-delay disabled=no \
interface=bridge2 lease-time=4h name=LAN_dhcp
/tool user-manager customer
set admin access=\
own-routers,own-users,own-profiles,own-limits,config-payment-gw password=\
XXX time-zone=+07:00
/tool user-manager profile
add name=30day_shared1 name-for-users="" override-shared-users=1 owner=\
admin starts-at=logon validity=4w2d
/tool user-manager profile limitation
add address-list="" download-limit=0B group-name=shared1user ip-pool="" name=\
shared1user owner=admin transfer-limit=0B upload-limit=0B uptime-limit=0s
add bridge=bridge1 interface=ether4-HOTSPOT
add bridge=bridge1 interface=ether5-HOTSPOT
add bridge=bridge2 interface=ether6-LAN
add bridge=bridge2 interface=ether7-LAN
add address=192.168.10.2/24 comment="WAN: ether1" interface=ether1-WAN \
network=192.168.10.0
add address=192.168.20.2/24 comment="WAN: ether2" interface=ether2-WAN \
network=192.168.20.0
add address=192.168.30.2/24 comment="WAN: ether3" interface=ether3-WAN \
network=192.168.30.0
add address=10.10.10.1/24 comment="HOTSPOT: bridge ether4-5" interface=\
bridge1 network=10.10.10.0
add address=10.10.20.1/24 comment="LAN: bridge ether 6-7" interface=bridge2 \
network=10.10.20.0
add address=10.0.10.1/24 comment="Access point IP to HOTSPOT" interface=\
bridge1 network=10.0.10.0
add address=10.0.20.1/24 comment="Access point IP to LAN" interface=bridge2 \
network=10.0.20.0
add address=10.10.10.0/24 comment="HOTSPOT pool" dns-server=10.10.10.1 \
gateway=10.10.10.1
add address=10.10.20.0/24 comment="LAN pool" dns-server=10.10.20.1 gateway=\
10.10.20.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip firewall address-list
add address=192.168.20.0/24 comment="WAN1: 192.168.20.0/24" list=WAN2
add address=192.168.30.0/24 comment="WAN1: 192.168.30.0/24" list=WAN3
add address=192.168.10.0/24 comment="WAN1: 192.168.10.0/24" list=WAN1
add address=10.10.10.0/24 comment="HOTSPOT: 10.10.10.0/24" list=LAN_HOTSPOT
add address=10.10.20.0/24 comment="LAN: 10.10.20.0/24" list=LAN_HOTSPOT
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
add action=add-src-to-address-list address-list=bit-list \
address-list-timeout=1m chain=forward comment="Block Bittorrent" \
dst-address-list=!bit-unblock-list layer7-protocol=layer7-bittorrent-exp \
src-address-list=!bit-unblock-list
address-list-timeout=1m chain=forward dst-address-list=!bit-unblock-list \
layer7-protocol=layer7-bittorrent-exp src-address-list=!bit-unblock-list \
src-address-type=local
add action=drop chain=forward dst-port=!80,443 protocol=tcp src-address-list=\
bit-list
add action=drop chain=forward protocol=udp src-address-list=bit-list
/ip firewall mangle
add action=accept chain=prerouting dst-address-list=WAN1
add action=accept chain=prerouting dst-address-list=WAN2
add action=accept chain=prerouting dst-address-list=WAN3
add action=accept chain=prerouting disabled=yes dst-address-list=LAN_HOTSPOT
add action=mark-connection chain=input comment="INPUT: mark connection" \
connection-mark=no-mark in-interface=ether1-WAN new-connection-mark=\
WAN1_conn passthrough=yes
add action=mark-connection chain=input connection-mark=no-mark in-interface=\
ether2-WAN new-connection-mark=WAN2_conn passthrough=yes
ether3-WAN new-connection-mark=WAN3_conn passthrough=yes
add action=mark-routing chain=output comment="OUTPUT: mark connection" \
connection-mark=WAN1_conn new-routing-mark=to_WAN1 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN2_conn \
new-routing-mark=to_WAN2 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN3_conn \
new-routing-mark=to_WAN3 passthrough=yes
add action=mark-connection chain=prerouting comment=\
"PPC HOTSPOT: WAN1 (200Mbs) + WAN2 (200Mbs) + WAN3 (50Mbs)" \
connection-mark=no-mark dst-address-type=!local hotspot=auth \
in-interface=bridge1 new-connection-mark=WAN1_conn passthrough=yes \
per-connection-classifier=both-addresses:9/0
add action=mark-connection chain=prerouting connection-mark=no-mark \
dst-address-type=!local hotspot=auth in-interface=bridge1 \
new-connection-mark=WAN1_conn passthrough=yes per-connection-classifier=\
both-addresses:9/1
both-addresses:9/2
both-addresses:9/3
new-connection-mark=WAN2_conn passthrough=yes per-connection-classifier=\
both-addresses:9/4
both-addresses:9/5
both-addresses:9/6
both-addresses:9/7
new-connection-mark=WAN3_conn passthrough=yes per-connection-classifier=\
both-addresses:9/8
"PPC LAN: WAN1 (200Mbs) + WAN2 (200Mbs) + WAN3 (50Mbs)" connection-mark=\
no-mark dst-address-type=!local in-interface=bridge2 new-connection-mark=\
WAN1_conn passthrough=yes per-connection-classifier=both-addresses:9/0
WAN1_conn passthrough=yes per-connection-classifier=both-addresses:9/1
WAN1_conn passthrough=yes per-connection-classifier=both-addresses:9/2
WAN1_conn passthrough=yes per-connection-classifier=both-addresses:9/3
WAN2_conn passthrough=yes per-connection-classifier=both-addresses:9/4
WAN2_conn passthrough=yes per-connection-classifier=both-addresses:9/5
WAN2_conn passthrough=yes per-connection-classifier=both-addresses:9/6
WAN2_conn passthrough=yes per-connection-classifier=both-addresses:9/7
WAN3_conn passthrough=yes per-connection-classifier=both-addresses:9/8
add action=mark-routing chain=prerouting comment=\
"Mark packets from each connection to to proper routes " connection-mark=\
add action=mark-routing chain=prerouting connection-mark=WAN2_conn \
add action=mark-routing chain=prerouting connection-mark=WAN3_conn \
add action=masquerade chain=srcnat comment=\
"NAT to make local IP to be able to go to extranet" out-interface=\
ether1-WAN
add action=masquerade chain=srcnat out-interface=ether2-WAN
add action=masquerade chain=srcnat out-interface=ether3-WAN
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
src-address=10.10.10.0/24
/ip hotspot walled-garden
add dst-host=:^www.apple.com
add dst-host=:^www.airport.us
add dst-host=:^www.itools.info
add dst-host=:^www.appleiphonecell.com
add dst-host=:^captive.apple.com
add dst-host=:^www.thinkdifferent.us
add dst-host=:^www.ibook.info
add check-gateway=ping distance=1 gateway=192.168.10.1 routing-mark=to_WAN1
add check-gateway=ping distance=1 gateway=192.168.20.1 routing-mark=to_WAN2
add check-gateway=ping distance=1 gateway=192.168.30.1 routing-mark=to_WAN3
add check-gateway=ping distance=2 gateway=192.168.20.1
add check-gateway=ping distance=3 gateway=192.168.30.1
/radius
add address=127.0.0.1 secret=1234 service=hotspot
/radius incoming
set accept=yes
/tool user-manager router
add coa-port=1700 customer=admin disabled=no ip-address=127.0.0.1 log=\
auth-fail name=mikrotik shared-secret=1234 use-coa=yes
