Urgent : problem with ( TR6 and RB 433 H ) link
Dear all
please,i need your help in config the Tranzio TR6 with Mikrotik 433H,
i have donr all the setting and i can see the Tranzio in my Registration List ( inside rb433h ).
but i lost it every few second. and i didnt get a ping between.
You aren’t posting enough information about your hardware and software configurations, line of site, distance, signal, ccq, etc, etc, etc,
SORRY FOR THAT
distance is : 14 km
line of sight
best segnal : -89 db
i cant get any more details becouse the link keep, connect and disconnect.
-89 is very very low signal for that reason you have connect disconnect.
What antena you are using ?
Check cable and antena angliment.
hello
i have used a 433h on same cable and antenna, and i get a very good segnal.
i wana know, if there any more setting must done with Tr6, or its the same that we use with 433h.
