By mistake I set a schedule for restarting the MK every 10 seconds. My hardware version is Routerboard 433AH.
I’ve tried resetting with a metal object, but did not work.
Do you everybody can help?
/system schedule disable [/system schedule find]
Hook up a console cable, wait for the router to boot, QUICKLY log in, and paste the above into the CLI.
Beyond that you’re looking at resetting the router - NetInstall, and don’t keep the existing configuration.
Reseting the mikrotik WILL DELETE everything. Passwords, configurations etc. If it did not, then you did not reset it properly.
http://intellcom.net/docs/Mikrotik_RB433_manual.pdf
