Hello everybody i read alot before i post but no one give a good solution on how can i redirect http://www.XY.com to http://www.WZ.com in MT 2.9.27, it work fine in MT3.10 cz there is a redirect option in webproxy but there is no such option in 2.9.27 and plz don tell me to upgrade cz i don wanna loose my 70 gb cache files it’s help me alot in my bandwidth and i have a licence so there is anyway to redirect a website in MT 2.9.27?
best regards
Post a screenshot of your license key so we at least know you are using a legal license. Then I’m sure nobody will give you trouble about using 2.9.27
sure why not this is my license:
or link: http://img113.imageshack.us/my.php?image=licensewx6.jpg
now any help plz?
best regards
You should be able to create a firewall redirect rule and redirect from one IP to the other.
can u give me an example plz. to redirect http://www.abc.com to http://www.xyz.com.
best regards
in /ip proxy access add redirect-to=“abc.om” dst-host=“dfg.com” action=allow
something like that.
also see if proxy is enabled and caching if unnecessary is disabled.
it didn’t work with MT 2.9.27
no such argument (redirect-to)
any help plz?
best regards
sorry, no argument = no help. only upgrade
