URL to get latest versions of ROS branches
I need to know which versions of each ROS branche is the latest, as I adding up monitoring scripts. The only way I know to find out versions is RSS feed i can parse for the info.
But then, when I check for ROS updates within ROS, it can easily find out which version is the latest, so it looks like there should be some HTTP-request that can answer this question.
So my question is, how can I know the latest version for bugfix and current branches in some easy to parse request?
Thank you!
Here you go:
~ normis$ curl https://mikrotikdownload.s3.amazonaws.com/routeros/LATEST.6
6.41.2 1517920142
~ normis$ curl https://mikrotikdownload.s3.amazonaws.com/routeros/LATEST.6rc
6.42rc35 1519641969
~ normis$ curl https://mikrotikdownload.s3.amazonaws.com/routeros/LATEST.6fix
6.40.6 1519124692
Thank you Normis,
this is a hidden knowledge one can only know by chance :slight_smile:
Hi Normis,
by any chance are there an URL I can use to monitor Winbox updates as well? Nice to have a reminder on that, just in a case! )
Please!
Sorry for dredging up an old post but I wanted to share the new URL’s as the previous URL’s mentioned by @normis have stopped being updated. I was about to post a new post but then worked out the new URL’s.
# curl https://download.mikrotik.com/routeros/LATEST.6
6.46.5 1586248107
# curl https://download.mikrotik.com/routeros/LATEST.6rc
6.47beta54 1586154743
# curl https://download.mikrotik.com/routeros/LATEST.6fix
6.45.8 1579763985
Hope this helps someone else.
Thank you very much, I just started to check why my check-for-update script stop sending me notifications!
https://download.mikrotik.com/routeros/LATEST.7rc
and
for now return 7.12.1 1700221125
How to check for curent (7.15.1)
https://download.mikrotik.com/routeros/NEWESTa7.<channel>
curl https://download.mikrotik.com/routeros/NEWESTa7.stable
# 7.15.1 1717764551
curl https://download.mikrotik.com/routeros/NEWESTa7.testing
# 7.16beta2 1718183008
Or to get just the version, awk works:
curl -s https://download.mikrotik.com/routeros/NEWESTa7.testing | awk '{ print $1 }'
