I need your help. I have searched everywhere for power adapters for the RB951G-2HnD which are type A or B (USA compatible).
Could someone point me in the direction of an EU supplier who might have >100 of these in stock now?
Many thanks,
Luke
Many thanks,
Luke
Hi.
Try to get any compatible (12 or 24V / 1A) adapter somewhere. (Alibaba or any cheap distributor…)
Regards: Xen
Or eBay is full of these power supplies. Whatever voltage between 10-28v will be good. Voltages over 20v are suggested. 5 watts will be enough.
I am Venezuelan living in Spain right now. In my country (Venezuela) like many other American countries we use the American Plugs (A and B).
I had/have the same problem, bringing equipment here, and when I travel to America…
Maybe, my personal recomendation, and is better (I think so) is to but the Europe-America adapter in an electronic store, the price is about 50 cents in Spain, and use it. If you want to keep permanently, use a fast glue and setup fixed
. Is the best my friend.
You don’t transformer from 220 to 110 is you are using switching power transformer, because they are automatic 100-240, just you need a pin-plug adapter and the are very cheap.
I am talking about THIS:
http://ecx.images-amazon.com/images/I/41c7D4rRR4L._SY300_.jpg
Before buying a power adapter make sure it supports the amperage you need. You can buy them from anywhere from amazon as well. Get an earthed one.
