I agree… however there are some security precautions that should be taken anyhow, like changing from port 80 to something else. If anything is on port 80 at all its asking for a hack.
Just one IP address is not enough - an address LIST would be much better.
BTW: This is a problem in many other areas of ROS - maybe a good (and very easy) improvement for the next release!?!?!
You really need to think about what unsolicited traffic you’re allowing into your router from untrusted networks. Work on the principle of Deny everything, then let in what you absolutely need. This is done with the INPUT chain.
In this example, the router operates as a DNS cache and VPN server. So, the required rules in the input chain are as follows:
8 ;;; Drop TCP invalid
chain=input protocol=tcp connection-state=invalid action=drop
9 ;;; Permit local LAN traffic
chain=input in-interface=Internal action=accept
12 ;;; Accept Internet Established
chain=input in-interface=Internet connection-state=established
action=accept
14 ;;; PPTP Tunnel
chain=input protocol=gre action=accept
15 ;;; PPTP control
chain=input protocol=tcp dst-port=1723 action=accept
57 chain=input in-interface=Internet action=drop
Rule 9 is pretty permissive in my example. You may wish to tighten this to restrict access from the local LAN if required. As DNS queries to the ISP are initiated from the router, returned answers will be allowed in by rule 12.
Remote management is handled by using a VPN connection.
