Usage info
Is there a way for a mikrotik to store such data regardless of rebooting and power loss? I noticed that every time router is rebooted or there is a power loss I am loosing all the usage stats from the queue. Shouldn’t the router remember that stuff?
-edit- I am using 493AH w 3.25ROS
What’s new in 3.27:
*) fixed memory leak in DNS;
What’s new in 3.26:
*) fixed hotspot problem - deadlock was possible on multi-processor routers;
*) fixed problem - it was possible for RouterBOARD to loose configuration
after upgrade to RouterOS version 3.25;
*) added MetaROUTER support on RB1000;
*) using pptp and eoip tunnels simultaneously could crash router;
*) api - “comment” property was not accessible, fixed;
*) console, api - fixed handling of decimal fractions in time interval values;
*) bonding interfaces could sometimes disappear after reboot;
*) changed mesh protocol to send routing packets to broadcast address;
*) automaticly add ppp client interface when GPRS/3G modem is plugged in;
*) added simple/advanced mode to ppp client in WinBox;
*) added support for Huawei E1550 UMTS/HSDPA modem;
*) added support for Cricket Wireless A600 modem;
*) added support for yet another Globetrotter HSDPA modem;
*) added support for Sony-Ericson MD300 modem;
*) added support for ZTE MF626 & MF627 modems;
I suggest you either upgrade or downgrade.
