USB 3.0 Port on x86 motherboard
Hi, I am looking for help to install routerOS x86 on a new generation motherboard with USB 3.0 ports only. I try to adjust the BIOS but it has legacy mode. Wonder if USB 3.0 from intel is supported.
x86 has very limited USB3.0 support, it will probably work only in 2.0 mode.
Will more support for USB 3.0 add? I found a mulii LAN port fanless x86 MB to replace the existing one with a noisy fan. However, it has USB 3.0 ports.
Understand the current limitation. Fortunately the x86 motherboard has a serial port for me to set up initially
But will there be plan for adding USB 3.0 support?
If anyone’s reading this, I confirm that X86 board (intel CPU) Usb3.0 (LTE, flash drive, maybe including keyboard…) works very well on version 7 stable
