Greetings. ![]()
I have a problem with my brand new RB 951Ui-2HnD.
I want to share my internet connection from a 3G modem (model Huawei Optus) to the WLAN (as an AP bridge).
I have checked that the WLAN is OK, I can create AP..
I also checked that the USB port is OK, as well as my 3G modem.
I can connect my modem with no problem at all (plug in the usb modem β RB detects it β dynamically add PPP-out interface β RB gets dynamic IP address and gateway β I can ping to Internet).
ONLY IF I disabled the WLAN.
When I enable the WLAN, the USB modem abruptly goes off, and the PPP-Out interface disconnects. Then if I try to manually disable and enable the PPP-Out interface, it just canβt connect.
Any ideas? ![]()
Thanks. ![]()
