USB 3G modem (ONDA MT833UP) working on RB411GL
If anyone interested, here my experiences with RB411GL and 3G USB modem ONDA MT833UP (provided with connector for optional external antenna).
Borad Name: RB411GL
RouterOS Version: 5.21
[admin@MikroTik] /system resource usb> print
DEVICE VENDOR NAME SPEED
0 2:1 RB400 EHCI 480 Mbps
1 2:2 Onda MT833UP 480 Mbps
2 1:1 RB400 OHCI 12 Mbps
[admin@MikroTik] > port print
Flags: I - inactive
NAME CHANNELS USED-BY BAUD-RATE
0 usb1 2 serial-terminal 9600
[admin@MikroTik] >
[admin@MikroTik] /interface ppp-client> print detail
0 X name=“3G” max-mtu=1500 max-mru=1500 mrru=disabled port=usb1 data-channel=0 info-channel=0 apn=“ibox.tim.it” pin=“” user=“” password=“”
profile=default phone=“*99#” dial-command=“ATDT *99#” modem-init=“ATZ;AT+CGDCONT=1,“IP”,“ibox.tim.it”” null-modem=no dial-on-demand=no
add-default-route=yes use-peer-dns=yes keepalive-timeout=30 allow=pap,chap,mschap1,mschap2
[admin@MikroTik] > sys serial-terminal usb1 channel=1
[Ctrl-A is the prefix key]
atz
OK
atio
Mx83.HW.B01
EAGLE_R1.5.5.3VCL314831
ERROR
