USB 3G modem only 4 WinBox
Hello!
Is it possible to use an USB 3G modem only for WinBox remote management? And how to set up correctly?
All other traffic goes thru wired connection.
Thanks in advance
Hello
I can not get past the configuration now but I can give you an idea how to do it.
1 - Install 3G modem standard procedure and put default route of it as distance = 2
2 - Dial inbound connections from the 3G modem to return by the 3g modem like what happens in PCC
3 - In mangle dial so that the flow of the local network leaves only by the main link
Thank you!
