USB 3G modem : ZTE MF667 model
Hello:
I am trying to configure a USB 3G modem : ZTE MF667 model.
[admin@MikroTik] > /system resource usb print
DEVICE VENDOR NAME SPEED
0 1:1 RB400 EHCI
1 1:7 ZTE,Incorporated ZTE WCDMA Tech
[admin@MikroTik] >
[admin@MikroTik] > /port print
Flags: I - inactive
NAME CHANNELS USED-B
[admin@MikroTik] >
Any idea why not on /port print
Regards
please try to contact the support@mikrotik.com for a test release of v6.8rc1 and provide then a support output file.
Is there a fix for this? I’m trying to also get a MF667 to work. I use the latest version 6.12.
Regards
Did anyone got these working?
I am sending a supout.rif to support but our project will force us to replace the modem with another one due to tight scheduleds.
BR.
This stick works including sms.
Dial Command: ATDT
Data and Info Channel 1
But you need to enable serialmode and disable CD-Rom. You can do this from a Windowspc :
Insert the stick and install it. Backup the files from the virtual CDRom. Visit: “http://192.168.0.1/goform/goform_process?goformId=MODE_SWITCH&switchCmd=FACTORY” to enable serialconsole. maybe you need to and log in to the serialconsole and send “AT+ZCDRUN=8 disable”
I needed to find the serialdrivers on the net to pass the command from windows, but i think you can send them from Routeros too.
Thanks to Tobiassorg for the hints: http://www.ip-phone-forum.de/showthread.php?t=283135
