Hi. I’ve just put a pendrive on my 2011 (ros 6.24)
It didn’t recognize it, but it did after a reboot (weird).
Then, I’ve seen usb1 on Files.
But I cannot format or check it:
- under Stores I just see 0kb used / 0 kb free
- under Disks → format drive → I see “action not permitted” and a weird “device name”
- if I try to remove the above Store, it says “not implemented”
… What happens ???
