USB Forwarding
Hi All,
I would like to use a x86 board using RouterOS with Xen support to run a Linux DomU and use a USB device connected to the host. Is RouterOS configurable to forward the USB device or even the complete USB controller using forwarding? The forwarded device will be a simple usbserial device, nothing fancy.
If RouterOS could support this it could benefit VoIP setups because line-cards could be PCI forwarded to a DomU running Asterisk.
With kind regards,
Joffrey
