USB LTE Bridge Mode: Laptop gets IP but MikroTik RB750Gr3 doesn't
Help Request: Connecting USB LTE Modem with Static IP in Bridge Mode to MikroTik hEX RB750Gr3
Hardware Specifications:
  • Router: MikroTik hEX RB750Gr3 (RouterOS v7.20.5)
  • Modem: D-Link DWR-910M (USB LTE Modem)
  • Service: Static IP from local ISP (requires external access)
  • Connection: Via router's USB port
Main Issue:
The DWR-910M modem connects to MikroTik in Bridge mode (NAT disabled) but:
  1. :white_check_mark: Device Detection: MikroTik recognizes the modem as usb1 in /interface print
  2. :white_check_mark: Laptop Connection: When connected directly to a laptop, the laptop obtains an IP without APN configuration
  3. :cross_mark: MikroTik Connection: DHCP Client on MikroTik fails to obtain an IP
  4. :cross_mark: Manual IP: Even with manual IP settings (matching laptop settings), no connection is established
Strange Behavior:
  • Modem in Router mode (NAT enabled) easily provides IP to MikroTik
  • In Bridge mode, it only provides IP to a laptop (Windows)
  • After enabling Bridge mode on the modem, access to its admin panel is lost (until hard reset)
Steps Taken:
  1. Configured DHCP Client on usb1:
    /ip dhcp-client add interface=usb1 disabled=no
  2. Tested manual IP with laptop settings
  3. Temporarily disabled MikroTik firewall
  4. Changed MikroTik MAC address to match laptop's MAC
  5. Factory reset modem and reconfigured
Specific Requirements:
  • Bridge Mode Required: Static IP from ISP must reach MikroTik directly
  • External Access: Internal services must be accessible via Static IP
  • Limited Modem: DWR-910M lacks features like DMZ, Port Forwarding, or UPnP
Questions:
  1. Are there any known issues with RouterOS v7 and this specific modem in Bridge mode?
  2. How can I debug why the laptop gets an IP but MikroTik doesn't?
  3. Do I need specific USB or LTE configuration settings?
  4. Are there alternatives to Bridge Mode given these limitations?
Additional Information:
  • MikroTik does not recognize the modem as LTE, only as usb1 (standard USB network adapter)
  • In Bridge mode, the modem retains APN settings (since laptop connects without APN configuration)
Please advise if you have a solution or need more information.
*For better assistance, please provide specific codes or required commands.
(AI-generated text)*
Check this page:
If you want your specific device to be included, the only option is to make supout.rif when the device is connected and file a support ticket requesting it will be added.
