USB LTE modem with external IP functionality?
I read the supported hardware list in wiki(https://wiki.mikrotik.com/wiki/Manual:Peripherals). But I can’t distinguish which one of them has FULL functionality in LTE interface. May I get an answer from official staff? Or anybody has experience or recommendation? Thanks!
Buy wAP, LtAP or LHG LTE
I had these hardware already, but that just doesn’t fit my case. I’m heading for a USB modem. The peripherals wiki doesn’t state anything about LTE functionality. I’m quite wonder about that.
The mobile provider don’t provide public IP address, so you can not use functionality of public address, remote access to router, port forwarding etc..
Some MNOs actually provide public IP address to clients. However they mostly block incoming connections (for clients’ protection), hence the second part of post
is still very much true.
You can still set up a VPN to route your public IP.
I specially applied the static public IP on LTE, I confirm it works. But l need a USB modem for my application.
Many many services doesnt reliable with VPN. e.g. UDP based streaming without MTU configable.
