Hi, i have a more technical question, it;s safe to connect ~ 4 devices through a hub powered bus to the router usb port? Within safe i mean if it won’t overload the usb chip requesting more power than usually/it can deliver.. or the hub must be powered separately by an adapter?
No problem if the hub is powered with a adapter
You didn;t understand my question, is there any problem for the usb chip to handle/power x devices through the usb hub since i don’t use an power adapter for it
