USB -> RJ45 console cable for CRS?
Folks,
Where can one buy an RJ45 to USB console cable which would connect a modern laptop (which doesn’t have serial) to the RJ45 console port of the CRS125-24G-15-2HnD-IN desktop SOHO router?
Thanks!
While I continue my search, a coworker has lent me a spare Cisco DB9 → RJ45 console cable. I’m assuming these work with MikroTik hardware and am shopping online for a USB → RS232 cable which I can connect to the Cisco console cable.
Yes, this is the approach I use.
In case anyone else comes looking for answers on this, I’ve tested this setup with Fedora and it works OK. I didn’t see any setup docs on the wiki for Linux.
Configure serial connection for Linux
[] Use a Cisco-style RJ45-DB9 cable
] Use a USB → RS232 cable (I used a TrendNet TU-S9)
[*] Assumes you have the ‘minicom’ program installed on a Linux OS (I used Fedora)
sudo /bin/minicom -s
[] Set device to ‘/dev/ttyUSB0’
] Set hardware flow control to ‘off’
[] Set speed to 115200
] Save config
[*] Re-enter minicom system and you should be good to go.
I use Putty on device /dev/ttyUSB0 on linux.
COM port on Windows.
In case you use Windows 7 and are to buy an USB adapter, make sure to NOT buy a Prolific chip based adapter.
See my post about Serial Connection With Windows 7.
Zap.
Just FYI, for 3 years I’ve never noticed problems described by you using Prolific PL-2303 XA/HXA converter on Windows 7.
Regards,
