Hello, yesturday i got my first MK, a 433…one of the five leds was missing, but i did not care…
i got the UAH because of the USB ports, i do not really have a real use for them, but neither do i to have a MK at home XD
but i had one small problem, its driving me crazy and since im new to MK i decided to ask here…
my first idea was log to an SD card, but after the basic storage setup winbox started to acr kinda weird, some dialog boxes did not close after pressing “OK” and it started to lag some dialogs. like a PC crash… i tought the SD could be broken, so i replaced it for an old USB flash drive and it worked nicely during some hours of playing, but today playing with the logs i got the same behaviour but on a smaller scale…on the debug logs i got:
21:17:01 store,debug DISCO: adding new drive: usb1 (/dev/sda)
21:17:01 store,debug user-manager1: disk setup finished successfully
21:17:01 store,debug DISCO: user-manager1: disk setup finished successfully
21:17:01 store,debug pendrive: disk setup finished successfully
21:17:01 store,debug DISCO: pendrive: disk setup finished successfully
//non related info erased
21:30:43 store,debug DISCO: adding new drive: usb1 (/dev/sda)
21:30:43 store,debug DISCO: user-manager1: disk setup finished successfully
21:30:43 store,debug DISCO: pendrive: disk setup finished successfully
21:30:43 store,debug DISCO: web-proxy1: disk setup finished successfully
21:30:43 store,debug DISCO: activating store for web-proxy1
21:30:43 store,debug DISCO: web-proxy1: activation finished successfully
21:31:39 store,debug DISCO: adding new drive: usb1 (/dev/sda)
21:31:39 store,debug DISCO: user-manager1: disk setup finished successfully
21:31:39 store,debug DISCO: pendrive: disk setup finished successfully
21:31:39 store,debug DISCO: web-proxy1: disk setup finished successfully
some more after adding a proxy storage
22:02:10 system,info item changed by admin
22:07:00 store,debug DISCO: adding new drive: usb1 (/dev/sda)
22:07:00 store,debug adding new drive: usb1 (/dev/sda)
22:07:00 store,debug DISCO: user-manager1: disk setup finished successfully
22:07:00 store,debug user-manager1: disk setup finished successfully
22:07:00 store,debug DISCO: pendrive: disk setup finished successfully
22:07:00 store,debug pendrive: disk setup finished successfully
22:07:00 store,debug DISCO: web-proxy1: disk setup finished successfully
22:07:00 store,debug web-proxy1: disk setup finished successfully
22:07:01 store,debug DISCO: activating store for web-proxy1
22:07:01 store,debug activating store for web-proxy1
22:07:01 store,debug DISCO: web-proxy1: activation finished successfully
22:07:01 store,debug web-proxy1: activation finished successfully
22:08:36 system,info the proxy direct rule added by admin
22:08:41 system,info the proxy direct rule changed by admin
22:09:00 system,info the proxy direct rule changed by admin
22:10:14 system,info http proxy settings changed by admin
22:11:16 store,debug DISCO: adding new drive: usb1 (/dev/sda)
22:11:16 store,debug adding new drive: usb1 (/dev/sda)
22:11:16 store,debug DISCO: user-manager1: disk setup finished successfully
22:11:16 store,debug user-manager1: disk setup finished successfully
22:11:16 store,debug DISCO: pendrive: disk setup finished successfully
22:11:16 store,debug pendrive: disk setup finished successfully
22:11:16 store,debug DISCO: web-proxy1: disk setup finished successfully
22:11:16 store,debug web-proxy1: disk setup finished successfully
22:11:35 store,debug DISCO: adding new drive: usb1 (/dev/sda)
22:11:35 store,debug adding new drive: usb1 (/dev/sda)
22:11:35 store,debug DISCO: user-manager1: disk setup finished successfully
22:11:35 store,debug user-manager1: disk setup finished successfully
22:11:35 store,debug DISCO: pendrive: disk setup finished successfully
22:11:35 store,debug pendrive: disk setup finished successfully
22:11:35 store,debug DISCO: web-proxy1: disk setup finished successfully
22:11:35 store,debug web-proxy1: disk setup finished successfully
22:11:53 store,debug DISCO: hddproxy: disk setup finished successfully
22:11:53 store,debug hddproxy: disk setup finished successfully
22:11:53 store,debug DISCO: activating store for hddproxy
22:11:53 store,debug activating store for hddproxy
22:11:53 system,info hddproxy added by admin
22:11:57 store,debug DISCO: store for hddproxy activated
22:11:57 store,debug store for hddproxy activated
22:11:57 store,debug DISCO: hddproxy: activation finished successfully
22:11:57 store,debug hddproxy: activation finished successfully
22:12:11 system,info http proxy settings changed by admin
22:12:13 system,info http proxy settings changed by admin
22:13:26 system,info,account user eduardots logged in from 190.188.240.12 via winbox
22:13:59 store,debug DISCO: adding new drive: usb1 (/dev/sda)
22:13:59 store,debug adding new drive: usb1 (/dev/sda)
22:13:59 store,debug DISCO: user-manager1: disk setup finished successfully
22:13:59 store,debug user-manager1: disk setup finished successfully
22:13:59 store,debug DISCO: pendrive: disk setup finished successfully
22:13:59 store,debug pendrive: disk setup finished successfully
22:13:59 store,debug DISCO: web-proxy1: disk setup finished successfully
22:13:59 store,debug web-proxy1: disk setup finished successfully
22:13:59 store,debug DISCO: hddproxy: disk setup finished successfully
22:13:59 store,debug hddproxy: disk setup finished successfully
22:14:21 store,debug DISCO: adding new drive: usb1 (/dev/sda)
22:14:21 store,debug adding new drive: usb1 (/dev/sda)
22:14:21 store,debug DISCO: user-manager1: disk setup finished successfully
22:14:21 store,debug user-manager1: disk setup finished successfully
22:14:21 store,debug DISCO: pendrive: disk setup finished successfully
22:14:21 store,debug pendrive: disk setup finished successfully
22:14:21 store,debug DISCO: web-proxy1: disk setup finished successfully
22:14:21 store,debug web-proxy1: disk setup finished successfully
22:14:21 store,debug DISCO: hddproxy: disk setup finished successfully
22:14:21 store,debug hddproxy: disk setup finished successfully
22:15:31 store,debug DISCO: adding new drive: usb1 (/dev/sda)
22:15:31 store,debug adding new drive: usb1 (/dev/sda)
22:15:31 store,debug DISCO: user-manager1: disk setup finished successfully
22:15:31 store,debug user-manager1: disk setup finished successfully
22:15:31 store,debug DISCO: pendrive: disk setup finished successfully
22:15:31 store,debug pendrive: disk setup finished successfully
22:15:31 store,debug DISCO: web-proxy1: disk setup finished successfully
22:15:31 store,debug web-proxy1: disk setup finished successfully
22:15:31 store,debug DISCO: hddproxy: disk setup finished successfully
22:15:31 store,debug hddproxy: disk setup finished successfully
22:16:43 system,info,account user admin logged out via winbox
22:16:43 system,info,account user admin logged out via local
22:17:42 store,debug DISCO: adding new drive: usb1 (/dev/sda)
22:17:42 store,debug adding new drive: usb1 (/dev/sda)
22:17:42 store,debug DISCO: user-manager1: disk setup finished successfully
22:17:42 store,debug user-manager1: disk setup finished successfully
22:17:42 store,debug DISCO: pendrive: disk setup finished successfully
22:17:42 store,debug pendrive: disk setup finished successfully
22:17:42 store,debug DISCO: web-proxy1: disk setup finished successfully
22:17:42 store,debug web-proxy1: disk setup finished successfully
22:17:42 store,debug DISCO: hddproxy: disk setup finished successfully
store:
Flags: X - disabled, A - active
# NAME TYPE DISK STATUS
0 user-manager1 user-manager system backup
1 A pendrive user-manager usb1 active
2 A web-proxy1 web-proxy system active
DISK
Flags: S - system
# NAME TOTAL-SPACE FREE-SPACE STATUS
0 S system 520192KiB 472344KiB ready
1 usb1 999320KiB 981552KiB ready
is this normal to be shown from time to time or it should be printed only once?
does MK turn off the controller to save power?
